Cold start metal rattling noise
JadeMyWorld
Upstate NY
2024 Outer Banks Sasquatsh 2.3l
I typically remote-start my Bronco, so I didn’t notice the cold start noise until recently. It sounds like a metal rattling noise from the exhaust, but I could not hear it from underneath, nor could I find any loose parts.
If you listen to the video, the noise is more obvious starting from 30 seconds and disappears at 1 minute.
I have the Borla style exhaust.
Has anyone had similar experiences?
Bschurr
NY
If you didn’t find anything loose or rattling around underneath, perhaps give the exhaust a few good yanks back & forth to see if perhaps there is a loose baffle in there
JadeMyWorld
Upstate NY
Thanks. The baffle is in the muffler, right? The noise is close to the front wheel.
23OBX2.7
AB Canada
2023 Bronco
Could be the "normal" wastegate rattle
JadeMyWorld
Upstate NY
Good point. I will check the waste gate later to see if it’s loose. It sounds similar to some of the F-150s with the wastegate rattle.
23OBX2.7
AB Canada
2023 Bronco
Yeah too many Ford had ordered new turbo w integrated wastegate took months then when arrived called the rattle normal LOL there is an elastic band fix attaching it to the actuator shaft and and anchor to tension it eliminating the rattle but may void warranty hahaha.
