Climate Control
Jossman
1979 F150,2011 Mustang,2013 F150,2006 HD
No matter what the temp climate control seems to always be on.Have turned fan speed to lowest setting + adjusted temps but always air flow.
ChrisB351
Shreveport, LA
Fan speed is the only control that affects airflow (not temp). If the system is on youre going to have airflow so not sure exactly what youre asking. If you have recirculation off the speed will be greater when youre driving vs sitting still.
cracKen
Washington
23 Bronco Badlands 7MT
Turn the button to recirculate air inside only and not let air outside in.
AZ_Liberty
2007 Expedition
Um, you might want to tell us which climate control system you have.
I can certainly turn mine off, but I have the base system.
helifino16
Ron
Mount Sinai, NY (Long Island)
I've had a question about the AC all along...
The 'Auto' button illuminates three lights - what does these indicate? It seems to run the same no matter what setting I have it in. I cannot locate any explanation in the Owners Manual.
Ford Bronco Climate Control Dash
Also asked here.
Karl_in_Chicago
Karl
Chicago
Also asked here.
From my MY23 owners manual:
Ford Bronco Climate Control 1691526353205
helifino16
Ron
Karl_in_Chicago
Karl
Chicago
Thanks! Appreciated.
I'm still a bit dubious as to its true effectiveness but at least I understand what the lights are for! I initially thought I had some defroster or something on until I read the manual. Was just out today and IME it just changes the fan speed (and noise). My expectation, based upon years of other vehicles with auto-temp systems, is set it and forget it to a temp and the system manages to that with an initial ramp up (when needed) and then a taper off to a steady state. Perhaps I just haven't taken a long enough trip or the environment hasn't been right to allow it to work optimally but 3 lights = high fan, 2 lights = med fan, 1 light = low fan is how it has been working for me.
FWIW I have a May 23 build with the digital display on the knobs. It works fine and I'm happy, it's a small thing, it just appears to work quite differently than any other similar system I've used.
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
These digital knobs had been a resource issue for awhile. Are they standard again? I have Dec 22 build of MY23 and I have them.
FleshTuxedo
A
PA
'22 OBX 2dr.
If you want the fans completely off, press the button in the middle of the left temp adjustment knob. The fans will completely turn off
BigHoof
PA
Ram 2500
I think that is exactly what was asked. I too wondered why you couldn't turn off the fan. Pretty obvious now seeing the power symbol on the left knob. Thanks!
jrollo7
James
NY
Range Rover Sport
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
you can turn off the blower by pushing the button
