Chasing a Front Pass side door rattle - anyone else?
budnr22
VA
22 Badlands
I have aftermarket sub and when it hits certain bass frequencies I have a rattle on front passenger door. I did the window adjustment. I pulled the panel and added some dynamat and taped up everything I think could be causing the rattle. Even the plastic clips. But the rattle is still there. If I put a bit of pressure on the door panel the rattle goes away.
any ideas
Alassise
Al
any ideas
Remove the panel and play the same frequencies until you find the culprit. Then add more dynamat or anything that will make the part denser. If it is a panel, I will double the dynamat. I had the same issue with the tailgate and double it as much as I could, it reduced it but still there. Good luck!
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Check the passenger seatbelt. I've chased down multiple rattles that both times were the seatbelt rattling against the plastic.
budnr22
VA
22 Badlands
this is great guidance. I am 75% sure I have ruled out the seatbelt but is always a suspect. Thank you
budnr22
VA
22 Badlands
I think this is the way. Good thinking. Thank you
duel007
2023 4-door Bronco Badlands Lux Non-Sasquatch
Did you get this rattle squashed? I ruled out the seatbelt, and pressing on the door panel also stops mine. Doesn't sound like metal on metal.
Y2KFirehawk
PA
2022 Bronco Wildtrak
FWIW, I hear the same with my front doors during the winter
