- First Name
- Jeff
- Joined
- Feb 5, 2021
- Threads
- 29
- Messages
- 668
- Reaction score
- 1,492
- Location
- Boston, MA
- Vehicle(s)
- '21 CG Wildtrak, E.R.A. Cobra 427 S/C
- Your Bronco Model
- Wildtrak
I would start by removing your roof (if hardtop) and see if that makes a difference. one of my squeaks turned out to be the rear liftgate - which I discovered by driving around with it open and there was no Squeak - so I addressed that with a layer or stick on weather stripping along the top edge of the swing gate. Also, try simply loosening the top and shift it around a bit and let it re-seat itself and tighten. Also try checking to see if it's anything you've put in the rear storage areas. Beyond that, you need to have someone drive you around with you in the back and pinpoint the location.
