Car slightly shakes/vibrates idling in Drive but not in Neutral.
HCGxKaLiBeR
Tom
Simsbury, Connecticut
2018 Audi S4
2.7L Automatic, 12K miles, premium fuel.
Car shakes/vibrates, can feel it on the steering wheel. Not too severe, just annoying.
Only does it at red lights idle in Drive. Put the transmission in Neutral the vibrate stops.
Vibrate stops then the car moves. Drives normal, no check engine light, no other issues.
Torque converter? Transmission fluid? Any simple things to check without going to the dealership?
BigHoof
PA
Ram 2500
When you put the Bronco into gear, the idle drops so the engine must be running a bit rough. Back into neutral and the idle goes up and the engine smooths out. About all you can do is look for a loose hose or something. Not really transmission related.
lapazleo
2022 bronco badlands
Since when was a Bronco a car?
  • Love
Reactions: 0ne
HCGxKaLiBeR
HCGxKaLiBeR
Tom
2018 Audi S4
Thanks. I will check out the engine bay for anything that is out of the ordinary. I also plan to disconnect the battery to do a reset.
BigHoof
PA
Ram 2500
  • Haha
Reactions: 0ne
HCGxKaLiBeR
HCGxKaLiBeR
Tom
2018 Audi S4
  • Like
Reactions: 0ne
SuperDave150
Albuquerque, NM
Ford F-150, Ford Edge
I have found that my 2.7 Bronco is sensitive to bad gas (I.e., gas with water or other junk in it). Idles rough kinda like you say. I’ve learned that some water-remover treatment in the tank helps greatly - I use HEET brand.
https://www.goldeagle.com/brands/heet/
HCGxKaLiBeR
HCGxKaLiBeR
Tom
2018 Audi S4
Thanks buddy. I picked one up at AutoZone, it worked like a charm after a few miles in. Vibration reduced significantly. I guess I should take a pause getting cheap gas at Costco lol.
BroncocnorB
Paul
1965 Cobra,
It's definitely not a truck. SUV to be exact.
Wait, it has 6 lug wheels. What SUV. Has six lug wheels? And I consider the Tahoe/expedition class “SUV’” really light duty trucks with different bodies. I am so confused. Now the wrangler has 5 lug wheels…
BigHoof
PA
Ram 2500
A truck has a bed. No bed on my Bronco. Lugs have nothing to do with it.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.  
