Capable Bumper Lights
BigAlBronco
Alex
Ontario
Bronco, Sierra Dragster
I’m looking for options for fog light upgrades for the capable bumper. I want to replace the stock lights with amber fog lights but I am having no luck finding anything
CalvinT
Calvin
Phoenix, AZ
DBGBronco
Justin
Kamuela
24 BDSAS
Baja Designs Squadrons!! All their lens choices in Pro or Sport power!!
chrisg72
Medford, NJ
2024, 4dr, Black Diamond
helifino16
Ron
Mount Sinai, NY (Long Island)
Does anyone make an Ice Blue Fog light replaccement?
Ford Bronco Capable Bumper Lights Blue lights Fog
CalvinT
Calvin
Phoenix, AZ
AB8DT
Ron
Cedar Springs, Michigan
www.qrz.com
23 Bronco 4 Door HLE / 2024 F150 Crewcab
this is one of the nicest Broncos I have seen. Well done!
It has been a fun journey making it to where it is at the moment. Seems like there is no end to what you can do with these rigs. There is always something new to add or what to figure out & what will work. I would like to make it more overlanding capable... Only if I can get my wife to go camping :unsure::ROFLMAO:
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Look no further then our Dual Fog Kit w/Diode Dynamics Lights
https://www.4x4truckleds.com/diode-...brackets-for-2021-ford-bronco-capable-bumper/
We pair the American Made Diode Dynamics lights with our American Made mounting brackets for a plug and play installation.
One pair of lights operates from your factory fog switch while the 2nd set of lights is controlled from the overhead upfitters.
We even let you select what lights you get, so you can get a pair of fogs in white and a pair in yellow OR get whatever setup you want.
The lights also have a built in amber back-light for ambiance
Ford Bronco Capable Bumper Lights 1775685271306-7j
Ford Bronco Capable Bumper Lights 1775685280174-yv
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Another option for a direct replacement is the Baja Designs Kit here: https://www.4x4truckleds.com/baja-d...t-for-2019-2023-ford-ranger-2021-ford-bronco/
Or the Diode Dynamics Kit here: https://www.4x4truckleds.com/diode-...plastic-capable-bumper-2021-2023-ford-ranger/
The benefit to Diode Dynamics over Baja Designs is that you can get REALLY bright fogs as you can select either SPORT PRO or MAX (brightness goes up) and it has that built in amber backlight.
The benefit to Baja Designs is that you won't find a higher quality light out there.
Both come with a lifetime warranty
SPVPARTS
Lux Sponsor (Level 2)
Greenwood, IN
specialtyperformanceparts.com
Ford Raptor/Bronco/Mach E
Hey there, @BigAlBronco
We have several options available and can customize your kit however you'd like. We also have a complete line of patented plug and play harnesses that will make your install a breeze.
Here are some of our kit options:
SPV Parts 2022 UP Ford Bronco - Rigid Radiance/Scene Capable Bumper Fog Light Kit w/amber backlight - Including Brackets/Harness For Sale – Specialty Performance Parts
SPV Parts 2022 UP Ford Bronco Dual Baja Designs Squadron Sport & PRO C – Specialty Performance Parts
SPV Parts 2022 UP Ford BRONCO Rigid Industries D-Series PRO Capable Bu – Specialty Performance Parts
SPV Parts 2022 UP Ford Bronco (Capable Bumper) Morimoto 4Banger NCS & – Specialty Performance Parts
Feel free to reach out with any questions and I will be happy to help in any way possible.
Thanks!
Sidney @ SPV Parts
317. 934. 6778
CalvinT
Calvin
Phoenix, AZ
I bought the Diode Dynamics fog lights for several reasons.
1. They're amber.
2. They're twice as bright as the stock fog lights.
3. They have one of the sharpest if not the sharpest cut off of any fog light.
4. They look like the original lights.
5. I didn't have to add a bezel to make them look right.
The second photo shows how they mount and how to aim them. I took it so I'd remember where the screw is after I put the bumper back on. I figured out a way to pre-aim them before I installed them. They're about a inch low at 25 feet.
I bought mine from Diode Dynamics. Diode Dynamics includes the correct wiring.
Ford Bronco Capable Bumper Lights IMG_5174
Ford Bronco Capable Bumper Lights IMG_4514-1
4x4TruckLEDs.com
Adam
Lindenhurst, NY
CalvinT
Calvin
Phoenix, AZ
