Capable Bumper LED conversion.
Chrome_Pony
Chrome
The Great Land
Those of you with the MY22 "Capable" bumper have there been any manufacturers posting about LED kit development? All my searches show up the triple light kits for the modular bumper.
Looking for something in the vein of @Baja Designs fog pocket kit, like this version on a Ranger.
Ford Bronco Capable Bumper LED conversion. 1643328343897
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
bcl0404
Brendan
2017 F350
Also following here as interest in DD or BD fog light replacement in the stock capable bumper locations
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Can you explain the difference between the SAE, Pro, and Sport?
Linking to the Pro Baja Designs Fog Pocket Kit
SAE is a street legal light, not the brightest light out there but it's designed to be an SAE fog light
Sports are brighter and don't have as clean a cut-off as the SAE
Pros are even brighter
Beach_Bum
St. Augustine, FL
Are the Sports or Pros not street legal?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That is correct. Although I run Pros on my Raptor and have never had issues. I aim the lights down at the ground. But they are NOT street legal, but i've never had issues
Tarheel_Wes
Wesley
FJ
Bumping this up....looking for this but ALSO something to go in this pocket BESIDE the OEM Fogs on the capable bumper.
Like I'd really like to run the white OEM and an aftermarket amber.
Here:
Ford Bronco Capable Bumper LED conversion. Screen Shot 2022-01-25 at 10.48.24 AM
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
Here:
That's the perfect size for a @Baja Designs S2 light, but the surround might need some trimming, and it would be mounted sideways.
I have not tried any of my S2s vertically to see what the light throw pattern looks like, might need a 90° rotated lens pattern that BD doesn't have yet.
Tarheel_Wes
Wesley
FJ
Is the S2 a fog light? I was looking at ordering the dynamic diode ss3 and just seeing if they'd mount in there somehow....?
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
The S2 is a micro form factor 2 chip LED pod. Below are two S2 Pros flush in my Evil Mfg third brake light on my LWN Colorado. You can see the lens pattern is cut vertically, to disperse light horizontally.
Ford Bronco Capable Bumper LED conversion. 1643513977810
If the light was rotated 90°, as it would need to be in the capable bumper, the lens pattern would be horizontal, dispersing light vertically, instead of where you want it. It may be not a big deal, but it might fill in a blank spot in your forward-facing lighting oriented correctly.
Ford Bronco Capable Bumper LED conversion. 1643513547612
If that entire bezel section and OEM foglight is easily removable, the SS5 might fit in there and fill up the space pretty completely. Hard to say without one in hand, and mine is a Grangetober special, so unlikely to be seen that soon.
Ford Bronco Capable Bumper LED conversion. 1643513837888
Tarheel_Wes
Wesley
FJ
Nice, that's good info....so, on that Baja Design light, the light on the left is obviously not "cut" at all, so, how is if different from the one that is cut?
That's a good idea on removing the OEM Fog assembly and then having a bigger opening.....
I should have mine next week. Gonna take a close look at it.
Chrome_Pony
Chrome_Pony
Chrome
The Great Land
That is just one of the Baja Designs multiple lens types, called the combo lens. It has one spot and one flood in clear. Here's an example of the different types in amber: dual spot, combo, dual flood. Same is available with clear lenses.
Ford Bronco Capable Bumper LED conversion. 1643515054276
Both @Diode Dynamics and @Baja Designs produce modular lights, which means their lenses are swappable between amber/clear or spot/work/flood. You can buy them separate from the lights should you want to change things later.
Tarheel_Wes
Wesley
FJ
Which one of these would work best for traditional fog light use?
