Can the stop-start be programmed to only work when up to temp?
l88m22vette
IL
Please sir may I have locking diffs?
I don't actually hate using the stop-start with the clutch, its intuitive because its connected to the clutch pedal. I don't like that it starts working 2 minutes after I started the engine when its cold. Is there a way to program the stop-start to only work after a certain water or oil temp? Heck, I wonder if it could be built into those stop-start eliminator cables...
And, no, I don't want to wait until its warm and turn it on every time I drive 😏
RagnarKon
Ford Bronco, Escape, Focus
Definitely possible.
Not something you can easily do in Forscan. You’ll need to program a microprocessor to listen to and talk on the CAN bus.
22OBX
Hartford, AL
Toggle to Sport Mode and it auto disables. Some report success, some have not had the same luck with Forscan. Plenty to read on it if you search.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
That’s weird. I feel like mine kinda does that. It certainly has a mind of its own when it comes to when/if it will activate. If you have the heat or AC on or any big draw it seems to grey out the A and wait until it’s at full operation.
zombie
New Brunswick, Canada
Just push the button on the dash? Or just don't put the transmission in neutral until you're happy with the temps?
Ford Bronco Can the stop-start be programmed to only work when up to temp? 1695982445181
Bob
Illinois
Mustang GT
You can switch to sport mode or turn the switch on the dash off.
