Cam Phaser Issues
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
Has anyone experienced this on the Bronco Raptor? The last two days when I have cold started the first 5 seconds has a nasty, loud rattle. It goes away promptly but it sounds like a diesel starting up. Video attached. Is this the cam phasers failing?
Raptor911
Raptor911
Broadlands, VA
Yes! Sounds like the cam phasers. See video below from my 2018 Lariat with the 3.5. I did not know that the 3.0 had this issue
VelocityBronco
E
Cam phasers... Issue on the 3.5 for years, the 2.7 and i guess the 3.0. I can't believe Ford would continue building engines with this known issue, my 2012 F-150 has this issue, it has been fixed once and is doing it again...
Tye
Tye
Tye
San Francisco
Been researching this on raptor truck forum, has there been a long term solve yet? Many have had the issue come back even after the fix. After the service ive received at several different bay area dealers, Im not thrilled Im going to have to have one of them open up the engine. None of them have actually wanted to service the bronco raptor and dont seem to have a clue about it.
vrtical
Doug AI
GSMNP, TN
Fords
you get the added diesel sound.
HBTFD
Newnan GA
F350
My wife’s 3.5 had the cam phasers replaced at 42k. Fix worked for 2 years/35k miles. We traded it in at that point. At some point after the replacement a recalibration was done on the PCM to help the cam phaser issue. Reduced mpg by 1. During the life of the vehicle I used synthetic 5w-30 every 5k miles.
Tye
Tye
Tye
San Francisco
thanks. i am at 1600 miles as a point of reference. And i made sure to break the engine in for 1000 miles before going WOT.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Tye. Can you send us a DM with your VIN and dealership info? I can look into this for you.
Spooled
Republic of Texas
Raptor, Model 3
Break-in has nothing to do with this, you're good. This is an issue that has been plaguing ford for 10+ YEARS and they still can't fix the issue. Sad.
Raptor911
Raptor911
Broadlands, VA
my 2018 Lariat had it at 16K and fixed under warranty. Sold it at 42K and the issue never came back.
My 2019 Raptor never had it and I sold it at 13K miles
My 2021 Raptor at 10K miles does not have it either
If I were you, find a dealership that has done a few 3.5. I can't imagine it being that much different.
V1Rotate
Brevard, NC
2022 Wildtrak
Same issue that plagued the old 5.4 Triton’s too?
HBTFD
Newnan GA
F350
The repair does not require pulling the heads or bottom end of your engine. They’ll pull the valve covers and front cover off.
Holiday
Nate
Parkville, MO
Bronco Badlands!
Obiwan
Southwest
Don't care to share personal info
Tye what was your build date? This is a real bummer to see happening, especially at 1600 miles.
Tye
Tye
Tye
San Francisco
10/11/22
