Calm Screen??
HeliPilot
Kenny
CT
2022 2.7L SAS
It is in my instrument cluster as well. Have to set it up in MyView.
ctskier
Joshua
Norwalk
2024 Bronco Badlands 7 Speed (June 2024)
There is a calm screen on the instrument cluster. You can also turn off the display on the infotainment screen. Both are standard settings that don't require forscan.
YUP, i use calm screen, and I am quite happy with my instrument cluster
JeffL
Massachusetts
2019 Challenger Hellcat Redeye / 2023 Base SAS
its not in the raptor.
RaptorAU
RaptorAU
Chad
Auburn, AL
2024 Bronco Raptor
Can confirm it isn't but I'd think you can get it activated thru Forscan for the Raptor. It's gotta be there.
JeffL
Massachusetts
what would calm screen be then? just speedo / tach and maybe fuel level? you get the way better instrument cluster anyway.
Desert_Brush
SoCal
2015 Mini Cooper
You may be out of luck on that then, but on the bright side you do own a Bronco Raptor which is pretty rad.
roadsterlife
Freddy
MA
Bronco Raptor, Miata, BRZ
Aww thate's too bad, I wanted to use calm mode when in sport mode and baja exhaust on...
Bschurr
NY
Calm screen does NOT exist on the Braptor.
Calm screen DOES exist on Badlands, HLE and I am 99% sure on all other trims.
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
1 - manila folder
1 - pair of scissors
1 - roll of tape
____________
DIY Calm Screen
No idea anyone actually used that. I thought it was like turn signals on a white BMW.
I know you are kidding, but I have resorted to similar.
Why in the heck does Ford think its a good idea to force the screen to ULTRA bright when putting the vehicle in park. Especially when turning down brightness, does nothing? I get to work early, sit in the truck and relax for a few. But am blinded by the damn bright screen. Its ridiculous.
Fordified1
Bob
Mid South Texas
I want to ‘calm’ my screen by covering it with an analogue tachometer.
Fordified1
Bob
Mid South Texas
1 - manila folder
1 - roll of tape
____________
DIY Calm Screen
That’s how I calm my check engine light.
HotLap
Bradley
CA Central Coast
2023 Bronco, 2024 HD Street Glide & 2019 Yamaha XSR900
Right on!! Really think the “bar graph” tach is garbage, it’s too small, not bright enough to even see & mostly hidden behind the steering wheel. Plus it’s just counterintuitive to what you’re expecting to see. I’ve had many manual/autos in the past and always appreciate seeing an actual analog (or digital representation) of a tachometer gauge.
Fordified1
Bob
Mid South Texas
I especially needed an easy to read tachometer while in the mountains last week. Spent a lot of time manually shifting to lower gears descending extreme steep mining passes so I wouldn’t need to ride my brakes, but didn’t want to over rev it either.
