bvita
โ€Ž
โ€Ž
This bronco replaced a 18'JLU Rubicon and previously coming from f150 raptors and Tacomas, figured this would be a great vehicle. It's been almost two years into owning this it and it's one of my favorites. Finally deciding to put together a thread to share it.
Wheel / Tire:
- Rays 05x 17x8.5 -10
- Toyo RT Trail 37x12.5
- Volk Te37xt 17x8.5 -3
- BFG Km3 39x13.5​
- Project Kics R40 Iconix m14x1.5
Lighting:
- Baja Designs Lp6 White/Baja Amber - Drive Combo
- tig/4130 chromoly light hoop
- Baja Designs S2 Pro Baja Amber - Drive Combo
- RAD Designs Offroad 3rd brake / chase light
- Baja Designs S2 Pro / SAE
- Next Venture Motorsports bumper mount
Engine:
- YMS Racing Chargepipe / Blow Off Valve
Misc:
- OE Ford black bumper fascia
- R2DZ-17E810-YA 1X​
- OE skid plate powder coated satin black
- OE tow hooks polished smooth powder coated gloss black
Bought new on 2/19/24
Ford Bronco Bvita's Bronco Raptor Build IMG_8604
2024:
Ford Bronco Bvita's Bronco Raptor Build IMG_3577
2025:
Ford Bronco Bvita's Bronco Raptor Build IMG_6685
bvita
bvita
โ€Ž
โ€Ž
June 2024 - mounted a set of these Rays 05x with 37" Toyo RT Trails.
I have always had Rays / Volk Racing on a lot of my builds so it was a no brainer to continue the trend. These were a new product line from RaysMSC - Rays OffRoad, forged construction and made in Japan.
17x8.5 -10 Rays 05x / 37x12.5r17 Toyo RT Trail
Ford Bronco Bvita's Bronco Raptor Build IMG_3692
Ford Bronco Bvita's Bronco Raptor Build IMG_3699
Ford Bronco Bvita's Bronco Raptor Build IMG_3690
Ford Bronco Bvita's Bronco Raptor Build IMG_3695
Ford Bronco Bvita's Bronco Raptor Build IMG_3605
Ford Bronco Bvita's Bronco Raptor Build IMG_3618
Ford Bronco Bvita's Bronco Raptor Build IMG_3860
Photos were shot by @pureflowphoto on instagram
bvita
bvita
โ€Ž
โ€Ž
December 2025 -
I found a 2013 scab in terrain with 11k miles which was a fun vehicle along side the bronco.
Ford Bronco Bvita's Bronco Raptor Build IMG_5729
Mid perch and threw on the oe bronco beadlock capable wheels and 37" ko2's
Ford Bronco Bvita's Bronco Raptor Build IMG_5011
bvita
bvita
โ€Ž
โ€Ž
June 2025 - the stock bronco wheels were back on and RAD Designs Offroad hooked me up and sent me one of their billet 3rd brake / chase lights that uses a set of Baja Design s2's which adapt into the stock plastic 3rd brake light housing/surround.
Ford Bronco Bvita's Bronco Raptor Build IMG_8173
Ford Bronco Bvita's Bronco Raptor Build IMG_8168
bvita
bvita
โ€Ž
โ€Ž
July 2025 - threw in Eibach's 1" leveling springs and my new wheel/tire package came in.
Special ordered a set of Volk Te37xt's in Diamond Black and BFG Km3's. Tire Central in San Gabriel, CA has been my go to spot for mounting all of my wheels and has greatly taken care of everything.
17x8.5 -3 Volk Te37xt / 39x13.5r17 BFG KM3
Ford Bronco Bvita's Bronco Raptor Build IMG_9445
Ford Bronco Bvita's Bronco Raptor Build IMG_9446
Ford Bronco Bvita's Bronco Raptor Build IMG_9448
Also was super stoked to pick up these Project Kics R40 Iconix m14x1.5 lugs
Ford Bronco Bvita's Bronco Raptor Build IMG_8993
Ford Bronco Bvita's Bronco Raptor Build IMG_9091
bvita
bvita
โ€Ž
โ€Ž
September 2025 - wanted to update the front end a little bit more.
- Ordered ( R2DZ-17E810-YA 1X ) which is the black plastic fascia from the "Bronco Raptor Black Appearance Package."
- Skid plate was powder coated satin black to match the bumper
- tow hooks lightly polished and powder coated gloss black.
Felt like the OE Rigid fog/aux light were not bright enough and I preferred Baja Designs more. Also wanted something a bit more different than the stock housing replacement s2 kit. Found these Next Venture Motorsports bracket which bolts into the stock bumper which allowed me to mount a pair of s2 pros as auxiliary lights and s2 sae as my fogs. Did this option since it allowed for more adjustment and I like the look of the opening instead of the stock surround thats usually there.
Ford Bronco Bvita's Bronco Raptor Build IMG_0645
Ford Bronco Bvita's Bronco Raptor Build IMG_0661
bvita
bvita
โ€Ž
โ€Ž
Late September / Early November 2025 - have always wanted to mount some Baja Design Lp6's for a build ever since they came out. I knew the lp6 shape would compliment the bronco with the round headlights. Current market offerings and aftermarket bumpers were not my style and not a consideration.
I reached out to my fabricator with a couple photos of different mounts and let him work his magic. I really wanted a mount that sat as low as possible, as close as possible to the grille, and tube as the main design. He knocked it out of the park with the final product in my opinion. I also requested for 4130 / chromoly material for the whole mount. Starting off with the main tube / light mounts, he ended up rolling the tube to get a very close match to the bumper curve which also give the lights a nice sleek profile since I wanted to avoid having a straight tube.
Took some time to get the perfect measurement and took a couple attempts to find the right spacing since real estate is pretty tight behind the lights to accommodate the deutsch connectors and wiring, but ended up with this miter to position the rolled tube perfectly. Then tied it into a standoff tube that was capped. Only using 3/4 mounting bolts as it seemed super secure, which also helped clean up the overall mount without having a bigger plate for the mounts.
Had the opportunity to display the Bronco at OC AutoShow too!
Ford Bronco Bvita's Bronco Raptor Build IMG_1505
Ford Bronco Bvita's Bronco Raptor Build IMG_1524
Ford Bronco Bvita's Bronco Raptor Build IMG_1499
bvita
bvita
โ€Ž
โ€Ž
very stoked with the Bronco as an overall package.
Ford Bronco Bvita's Bronco Raptor Build IMG_6757 2
Ford Bronco Bvita's Bronco Raptor Build IMG_6747
Ford Bronco Bvita's Bronco Raptor Build IMG_6759
Swapped out some hardware for my light hoop and lp6's with ARP 12pt stainless bolts.
Ford Bronco Bvita's Bronco Raptor Build IMG_6763
RCVBAF
Brett
Caddo Mills TX
2023 Ford F-150 Heritage, Ford Ranger FX4, & 2025 Bronco
December 2025 -
Awesome Pair. Love the SC!
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
December 2025 -
I have the same pair. Love it
Bird Dog Off Road
Jody
Dallas, TX
www.youtube.com
December 2025 - very stoked with the Bronco as an overall package.
looks badass! Any rubbing when OffRoad yet?
bvita
bvita
โ€Ž
โ€Ž
How is the noise from the KM3's on the interstate?
Not bad in my opinion. Iโ€™ve had other sets of km3โ€™s make noise after being worn in a bit.
Iโ€™ve only experienced some minor rubbing in the rear by the mudflaps cruising around in the desert with it.
