Buying TPMS Sensors
MudMonsterRacin
PA
2003 Mach 1, 2016 F150
Where's is everyone buying their TPMS sensors for their spare wheels? Don't really wanna spend 200 bucks for a set.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
So as long as they're 315mhz they will work?
Not necessarily. I bought some that should have worked but didn't. The Tire Rack ones are more affordable than Ford and do work for sure.
rtaylor
R
ID
19Raptor, 22Bronco
tpms.com will pre-program them for Bronco (included in cost). If you buy an unprogrammed sensor on amazon or such, your installer will have to program them before they will work.
This is one that is similar to Ford OEM. There are cheaper options also.
Ford Bronco Buying TPMS  Sensors 1673151837599
BroncoAZ
Mitch
I second the Tire Rack ones. They have been flawless since I got them last Spring.
MudMonsterRacin
MudMonsterRacin
PA
Just looked them up. 143 bucks with tax. Not horrible.
Raptor911
Raptor911
Broadlands, VA
correct. I used the above on my 2021 raptor they work perfect. I have 5 bronco wheels with the same tpms and they should work. Will install them soon
Btw, I am about 95% sure that f150 and bronco share the same Tpms at 315mhz
MudMonsterRacin
MudMonsterRacin
PA
Is this the correct ford part number for the OEM tpms? The part numbers are definitely confusing TPMS35 F2GZ-1A189-A
Edit : Actually ford parts shows TPMS68 (1A189) as the part number and say they fit 2021-2023 f150 as well. They also look like the older style on their website and not the newer compact Schrader looking sensor.
Mdsuits
05 f350, 68 bronco 89 samurai
I just bought them at discount tire. They have to program them but they have worked fine.
66Fan
Tim
IL
2022 Wildtrak
tpms.com is selling OE and OE tier 1 manufacturers' replacement sensors.
The Schrader, Schrader EZ-sensor and VDO redi sensor are all top notch products. In the case of the standard Schrader sensor, it's the same one that is factory mounted.
Function_7
James
'Berta
Just my Bronco
Anyone have a coupon for their site? Looks good to me!
BroncoAZ
Mitch
No programming on mine. I installed the new wheels and the sensors programmed automatically in a few miles.
rtaylor
R
ID
19Raptor, 22Bronco
Note that programming is different than learning. A multi-protocol sensor that isn't programmed won't work if it isn't set to use the same protocol as the OEM sensor. After being programmed correctly, they will usually learn (be paired with Bronco) automatically with driving, or the pairing can be forced with a simple tool.
You can buy a factory-programmed or OEM sensor (highest cost),or have a multi-protocol sensor (such as Schrader EZ-sensor) programmed by distributor such as tpms.com or a tire installer with the proper programming tool. Tire shops only stock multi-protocol sensors since the same sensor can be programmed to work on many different vehicles.
Ford Bronco Buying TPMS  Sensors 1673203176384
