TheKim
Kim
Ford Bronco Broncos Pulling Trailers Pics - Add Yours PXL_20240831_001405948
Ford Bronco Broncos Pulling Trailers Pics - Add Yours PXL_20240526_123728281.MP
I don't have a picture of the hitch hooked up, but this is the one I'm using.
It's been great so far!
Ford Bronco Broncos Pulling Trailers Pics - Add Yours hitch
Here's a couple videos of it pulling it if anyone is interested - off-road I leave the stabilizers disconnected though 😁
bf4445
Britt
Oregon
2007LarietCC4x4, 2018FocusTit, 2016Jeep reneTH
Let me just say I am so grateful for this community. Never would've thought RV/Trailer shopping would be so damn complicated with a tow rating of 3500lbs but alas, here we are.
Stoked to stay I'm grabbing this bad boy over the weekend. 2700ish dry weight, 3500 gvwr. Used the ford points and installed the brake controller last night (not difficult just annoying).
Intech Sol Eclipse
you mean the Bronco does not have available a factory built in brake controler like my truck does?
Kevin Scarbel
Everglades
Kevin
Chesapeake, VA
2024 Bronco Everglades 4dr
Everglades
May I ask, what model is that Jayco?
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
A TBC is not available factory installed on a Bronco.
bf4445
Britt
Oregon
thanks for the info
I've come to love that feature it takes a lot of the load off the vehicles brakes....and i hate the addon systems been using them for decades.
Alex2124
Alex
Palatka Florida
2023 Bronco Big Bend
If I can get my Bronco back from the dealer I would have updated pics by now :( I've added a tongue box, roof rack and 270 awning to the camper since this pic.
Which brake controller are you using?
Alex2124
Alex
Palatka Florida
Which brake controller did you go with please?
Alex2124
Alex
Palatka Florida
We have full-timed in the r-pod for 14 months and counting. From SF to Chicago to Mexico and everywhere in between. Both the Bronco and r-pod have been flawless. Zipped up and down passes in ID, WY, CO, AZ, UT, and CA. Never once thought twice about it. And then we disconnect and go wheeling almost every Sunday. Well, did, until we slid backwards down a clay hill in Northen California, banged up every panel and 2 lights, hiked 5 miles out, and realized we were risking our home. We started with very little weight and of course kept adding as the Bronco continued to perform. I’ve taken it in for routine oil changes and service at various dealerships and nobody has said anything about noticing any wear or tear so I gotta think all systems are go.
Which brake controller did you go with?
NC_Pinz
NC_Pinz
Central NC
A little late but this was the Bronco out doing service work in WNC in December. The trailer pulls well at speed on the interstate and then in super tight spaces. I didn't get a pic of hitching the Bronco up to another trailer to deliver 200 gallons of water to a home on some steep gravel roads.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours ERT Bronco 1
NC_Pinz
NC_Pinz
Central NC
Another I forgot about. Not a trailer but our toad battery died and I went back to fetch. I will say the drive back was sketchy. 50 mph was fine but at 55 mph the handling started getting weird.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours Bronco Towing Mini
BroncoChallenger
2024 Bronco
Haven't taken any pics, but have hitched it up to a 20' aluminum walleye boat to launch it (.25 miles away) several times.
Oh, and then a couple weekends ago, went and got a new sectional on the flatbed with my truck. Turns out my truck with a 22' flatbed is too long to maneuver around my back yard. HOWEVER, putting my old hitch w/2-5/16 ball on it on the Bronco and hitching that up...well my only concern was getting into too tight of a turn and hitting the bumper on the tongue. Had PLENTY of room!
Rydfree
Benny
Alabama
Just ordered it!
It works great and is an easy install. I did not use the control bracket and mounted mine in the factory light switch bezel. The main control box I zip tied to the metal cross brace under the steering wheel and the factory plug it plugs into is just to the right at the top of the console. There is a blank in the connector you will need to pull out to plug the RedArc connector into. You just need to run 2 wires to the rear for Power and the brake control wire.
Ford Bronco Broncos Pulling Trailers Pics - Add Yours RedArc Pro Trail
Ford Bronco Broncos Pulling Trailers Pics - Add Yours RedArc connection
Alex2124
Alex
Palatka Florida
Mine has the factory tow package, I still have to power run lines to the trailer?
