BroncoBuster rear shock skid installed -- question
scojosmac
CO
f150 / bronco
Finally installed my broncbuster rear shock skids. I’m a little concerned and curious. Since it’s using the main 27mm shock bolt, we are losing a bunch of treads with the thick skid.
For anyone that has these installed, do you have gaps between the skid and bottom bracket/bolt or does it look like the bolt bends the skid to zip in enough ( used a Milwaukee impact )
I have the first iteration of these so I’m curious
@BroncBuster
Ford Bronco BroncoBuster rear shock skid installed -- question 6CF6D7ED-9B4D-4AAC-BA3C-DF0E86914EB2
Ford Bronco BroncoBuster rear shock skid installed -- question 18E036B0-5251-488C-A377-7F342278182A
Felix808
SRV CA
Looks to me like the skid is too wide and thus the bend in the sides.
Yep, but should still be ok as by the looks of it you got enough torque on it with your Milwaukee. Definitely keep an eye on it. I would also reach out to Tyler (Broncbuster) about it.
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
Mine were the same. I just sent it home with the impact. That’s a big old bolt and I gave it several ugga dugga’s
Defyfate11
Jaime
Clovis, CA
2020 Camry TRD
Mine did the same, even if the skid was tighter fitting there is a recess around the bolt so no matter what it will compress in.
