Bronco Wildtrak Stance (Front End)
Seven714
Seven714
Seven
Murrells Inlet SC
2023 Bronco Raptor
LSW I think you’re right but it appears to be higher in front almost like the front tires bigger. PS this isn’t a level surface.
Ford Bronco Bronco Wildtrak Stance (Front End) IMG_6473
  • Like
Reactions: LSW
LSW
L
North
'24 Bronco Wildtrak
I’d park it level then use a tape measure from the ground to the top center of all the fender flares. Most people are pretty happy if all the fender flares are equal in height, which is still a slight rake. I think that’s about what you’re at and it looks good to me. You could always consider lifting the rear with perch collars if you want more rake.
lewy
Kevin
PA
Mine does as well. It was about 1/2 in higher in front than rear.
I put a 6ft level on the door handles and the front is lower than the rear in terms of being level, I also measured from the ground to the bottom of the flare. Front 39“ Rear 39 1/2”. These measurements are after a 3/4“ body lift. Mine is a optical illusion as the rear looks lower to me.
Ford Bronco Bronco Wildtrak Stance (Front End) IMG_4351
Ford Bronco Bronco Wildtrak Stance (Front End) IMG_4350
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
My 2023 Wildtrak sat very high in the rear with the trailer towing package. Here it is with a 1.5" RPG collar and one spacer shim (.2" thick) on top of the strut mount. This combination lifted the front a little over an inch from it's original ride height. Rear is unaltered.
Ford Bronco Bronco Wildtrak Stance (Front End) Bronco level
