Bronco Team 2 door.
Deleted User 5719102
Who's
On a Lake
22 2dr
Got the Grumpster all detailed today. Ceramic coat and undercarriage detailed.
Ford Bronco Bronco Team 2 door. IMG_20230202_135705
Ford Bronco Bronco Team 2 door. IMG_20230202_135654
Ford Bronco Bronco Team 2 door. IMG_20230202_135640
Ford Bronco Bronco Team 2 door. IMG_20230202_135630
Ford Bronco Bronco Team 2 door. IMG_20230202_135617
Ford Bronco Bronco Team 2 door. IMG_20230202_135608
pakrat
JG
Lake Tahoe
Toyota 4Runner-F250-Tundra
What was the change in fluid volume of the diff with that cover?
When you install it the first time you mark the dipstick by aligning the factory cover up next to the arb cover. Then mark the dipstick at the height of the bottom of the fill hole from the factory cover. That way the level of the gear oil on the gears is the same. More oil is not better in the differential, it should cover the gears at the same depth regardless of the cover. It does come out to almost exactly the specified volume, so you could simply fill it with just under 2 qts. and then mark your dipstick for future reference. If you don't mark the dipstick there is no way to tell if it is full or not.
pakrat
JG
Lake Tahoe
"Computer-optimized, cross-brace design within the differential cover increases the structural rigidity of the axle acting as a truss"
I believe this is what you are referring to.
What they are talking about here is the design element. The outside design has extra material left to right to simulate a continuous support from axle tube to axle tube when bolted on. There is 2 bolts on each side aligned with the axle tubes. You can plainly see the extra structure that is built up across the cover acting like a truss or girdle. That extra material is on the exterior, not on interior of cover.Hopefully you can understand what I'm trying to say bud.
Let me try this again. Sorry Karl
@Grumpy What did you do with the brake lines? Can you take a closer pic? Did you just reuse the factory bolt and bracket or what.
Who's
On a Lake
22 2dr
I could not use the factory studs(2) as the nut flange is too wide for the machined cutouts. I am now, will be completed this weekend making new aluminum brackets to attach the brake line. I will post pics when complete.
Who's
On a Lake
22 2dr
Finally got the Havoc door sill plates in. Got to say I was impressed with the thickness and quality rubber these are made of. Fit perfect and held in place by 3m tape. The top flange even tucks up under the kick panel trim piece.
Ford Bronco Bronco Team 2 door. IMG_20230203_172139
Ford Bronco Bronco Team 2 door. IMG_20230203_172421
TyGuy40
Ty
Austin,TX
Triumph Bonneville
I wanted to post this beauty one last time before I say goodbye. We had an amazing 1.5 years together (give or take). I love this truck, but it was the right time to sell. I now have a beautiful baby girl, and I need something a little bigger for her, the dog, and my beautiful wife. Family comes first, but I know I will own one again one day. I did what I needed to do, drove all over the country, and wanted to thank this amazing community, with who I will continue to follow up with. And will happily do the Bronco wave whenever I see you, smiling, always remembering how much fun this thing is.....
A love so rare, between a man and his Ford
Together they roamed, from shore to the gorge
With tops off and wind, and the sun shining bright
This Bronco and man, a picture of delight
From beach to the Rockies, they had endless fun
Wife and dog by his side, and a love that was won
Their journey together, beauty to behold
A year of adventure, forever untold
But life moves fast, and a new chapter begins
The gift of a daughter is a love that wins
Though saying goodbye, is bittersweet pain
The Bronco lives on, in the memories it gained
So here's to the love, between man and his truck
To the moments they shared, and the memories they struck
Though it's time to move on, and make room for the rest
That time with his Ford, was some of the best.
So I bid you farewell
I'll try not to weep
You'll serve a new family
Better than any Jeep;)
Godspeed.
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
I have these too - highly recommend.
