Bronco Spring Rate Chart
CoolContractor
Fred
Can anyone post a chart of the front and rear spring rates of ALL of the models? I have a 2024 4 door Badlands with the tow package. Apparently there are many combinations of springs for the 2 door/4 door. Base/BL/BD/etc. 2.3L/2.7L. SAS/Non SAS. I want to buy a new set of coil overs for my Bronco and only want to lift it about 2.5" higher than stock in the front and the rear about .5" higher than the front to compensate for tools, recovery equipment, coolers etc. I don't mind the current spring/shock ride, so I would like to purchase some new coil overs that have the same or better ride characteristics, more articulation and with a 2.5" lift. The reason I want the stock spring rates is so I can find aftermarket coil overs that are the same or stronger than stock without being too stiff. I read that the Foxes and Kings are very weak in the rear causing a lot of squat when loaded down. (approx. 500 - 600 lbs.) Foxes offer stronger rear springs but how much stronger?
Ducati1098
As far as I know, no such chart exists
CoolContractor
Fred
I spent hours yesterday and today researching this with no success. I am ready to buy today if I can get these questions answered.
Sloth
SWFL
2022 Bronco
No such chart exists. Check out Dobinsons and Eibach for adjustable height coilovers with higher spring rates. Ive been happy running Dobinsons IMS with the highest available spring rates.
B22-2023
Houston
You can approach the vendors directly with this question - I’ve been in a similar exercise past few weeks, gathering info to go from where I am to what I need. See what the people who live/eat/breathe/sell the technology have to say for your particular issue if you can’t find the answer on the forum.
kodiakisland
Arkansas
Unfortunately some questions have no answer. There is very little data on actual spring rates. Hard to even keep up with how many different stock springs there are. Your best bet is to ride in a few different Broncos with aftermarket coilovers to see what you like. Get adjustable coilovers to fine tune it.
CoolContractor
Fred
I have been in contact with Fox regarding their 2.5 Elites.
Milner
Marc
SLC
2023 Wildtrak, 1995 OB PSD sold, 1998 XJ
This chart is what I have been able to compile so far. Some from other threads some from emailing the companies. Please let me know if you have more info or corrections.
