Factory spring rates
chtucker
Kirkland, WA
FJ Cruiser
I can't seem to find the specifics or a of the stock springs- I know that there are many different options though.
I am trying to get through my analysis paralysis- I need to at least level my ride back out from all my mods.
I don't want to do full coil overs-
I am looking OME springs or Bilstein springs on the following
stock SAS shocks
OME shocks
Bilstein 6100s
I know I am over thinking this, it's just what I do. My preference is the ARB heavy springs on the Bilsteins for the front and the OME medium springs on the Bilstein rears
I need to check compatibility of the OME springs, ARB says they are "different"
probably take my SAS shocks apart to see what the difference is.
Silver-Bolt
Bill
Eureka, MT
I have been looking for this info with no luck. If I can get ahold of the stock springs I have the ability to measure the strength.
chtucker
chtucker
Kirkland, WA
FJ Cruiser
Can I send you my FE SAS spring in the name of science?
Silver-Bolt
Bill
Eureka, MT
Can you get me some measurements from the spring? I need the I.D. (inside diameter) O.D. (outside diameter), the wire diameter, the overall length, and the number of coils. With those I should be able to determine the spring strength.
rusty603
Russ
NH
2017 Tacoma
I would think the actual grade and treatment of the steel used for the spring would be a significant factor. It would probably be more accurate to just load the springs. Have 2 big friends stand on the spring and measure the displacement.
Silver-Bolt
Bill
Eureka, MT
Automotive springs have a pretty standard material and heat treat. With the requested dimensions I can get very close on the spring rate. Worst case they can ship it to me and I will put it on the compression testing equipment.
rusty603
Russ
NH
2017 Tacoma
That makes a lot of sense, I didn't really consider that. I'll just follow to eventually see some results.
Bcol2012
Brandon
Houston
2014 Camaro ZL1
@Silver-Bolt Did you ever get an estimated or tested spring rate from the FE Sas Springs? I've got a BL Sas with Steel bumpers so I'm assuming I have the same springs.
Silver-Bolt
Bill
Eureka, MT
I haven't received any springs to test. Still willing to do it, just need the springs and vehicle specs.
da_jokker
Jeep Wrangler JKUR
I have no real interest in lifting my bronco, but I also would like to get back the 1" I lost from adding all my armor (and the harsher ride).
Not sure if some better springs would do it, or have to go coilovers.
