Bronco purchased
Mdozier
Nashville
95 F250, 24 Badlands
Congratulations. I’m sure you’ll get plenty WT owners offering options.
‘Welcome
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
I bought the Lobo HNT rear bumper. Not installed yet.
The others I was considering were the SVC and ADD bumpers.
Wannabe
Central WI
Gladiator, Wrangler, XT4
I’m not looking forward to dealing with parking sensors. I may want something installed.
Nanook
Jonathan
From all the different install videos for the different bumpers, the parking sensors seem to be a fairly straightforward process. 🤞
Wannabe
Central WI
I’ve heard they can be problematic because the new bumper is a different shape.
Nanook
Jonathan
Thats not installation, That’s more the design of the bumper and the sensors “seeing” things at new angles. You are correct that research will be needed for the bumper you choose.
Braaap
Outback
I went with the havoc bender rear bumper.
Ford Bronco Bronco purchased IMG_2615(1)
userdude
Denton, TX
2023 2dr Badsquatch
Do you have needs in mind? I've got the StinkyFab Sledgehammer high clearance rear bumper I'm about to install. The front sensors (I have the pair) were easy except all those bolt heads you see actually go to the brackets inside that hold the wires (on the front... that's what I've done). So it's annoying to drill all those out (there's a lot, on the front...).
One thing this bumper doesn't have is a step like stock (under the tire). If you think you're going to use that, just be aware to watch out for it.
Here's @StinkBug's install video for the rear bumper, he shows removing the sensors and gives some helpful tips like marking where they were and go.
Also, the Bronco in the video is a WT.
https://www.stinkyfab.com/collectio...sledgehammer-series-rear-bumper-for-bronco-6g
Wannabe
Central WI
Thanks
0ne
Nate
CO
Flex
Just get the factory “steel” rear bumper, tons with sensor holes for sale cheap in my local area. It’s a thinner steel shell with a plastic top tread plate. I find all the aftermarket offerings to be too angular and overbuilt.
Oldhippie
Barry
Santa Cruz, Calif.
I got A JCR, has holes but have no sensors…
Ford Bronco Bronco purchased IMG_0401
SixEighty680
2dr BadSquatch, 22 Indian Chieftain
Its official. I purchased a 2023 wildtrak. The only thing I don’t like is the plastic rear bumper. Any suggestions appreciated.
I mean...the rear bumper is steel, just has some plastic covering on parts, like the spot to extend it to match the sasquatch fender.
Wannabe
Central WI
My rear bumper is 100% covered in plastic.
