Bronco Outlets (110V)
RHeinz
Ric
Houston, TX
Not sure that could be done, what power are you looking for? It's 400W (in park) 300w (in drive).
Why would there be a difference? It’s powered by an inverter…..
RyanRallyX
04 Tacoma, '12 Pilot, '21 Bronco
Back of center console on '21 Black Diamond 2 door with Mid package.
Haven't tried he 110V (400W), but be aware the USB ports are for power only, and radio will not read them. The front USB's in the center at bottom of dash will power the phone and the radio will read my music USB stick.
Ford Bronco Bronco Outlets (110V) 20221009_113555
RHeinz
Ric
Houston, TX
Here is a photo of a cheap 2000 watt inverter. This would be capable of powering your George Foreman Grill. Note the size of the 12 volt DC supply wiring that is required.
Ford Bronco Bronco Outlets (110V) 82A3B171-C380-4766-AB93-A3EA230380EA
Ares
Fox
Atlanta
Is it possible to increase the wattage on the power outlet ?
its going to be bottlenecked by the alternator.
I dont think we can really know what the exact limit is for the alternator as far as hooking an inverter up to the battery terminals directly. but Id say going over 400w is going to be risky. Atleast for sustained draw.
Roger123
Roger
VA Beach, VA
Not sure? Maybe the car has more free juice when not driving?
Ford Bronco Bronco Outlets (110V) B63D2E4B-60EA-4718-AAD4-D258F969907E
RHeinz
Ric
Houston, TX
Not so.
You can run an inverter off of a 12 volt battery until the voltage goes too low for the inverter. No charging source required.
The Bronco specs indicate the alternator (2.7L) can supply 240 amps at 12 volts. This would sustain a 2800 watt inverter.
Ares
Fox
Atlanta
Not so.
You'd have to discount the system draw for the car itself. not sure if thats a negligible amount.
Or if the alternator is capable of running non-stop.
Boltstop
Rudy
Idaho
69 Bronco 302
Well since we are on the topic is it possible to put a high output alternator and and a second battery and wire it to an inverter that could run anything else upto 1500 or 2500 watts ?
GypsyDRB
Charlotte
2022 Bronco Badlands Sasquatch
answered my own Q...
nwGTS
Nate
Chicago, IL
Bringing this thread back from the dead.... does the Bronco's built-in 110V AC inverter outlet produce a pure sine wave or a modified sine wave?
Ford Bronco Bronco Outlets (110V) 1686321611019
nwGTS
Nate
Chicago, IL
paleh0rse
Bronco and others
oof. thanks.
not good and glad I found out before plugging in any sensitive equipment.
I'm currently researching DC-DC Converter options to get some pure sine wave power inside the truck. Not too difficult to solve, but spending another $150+ to accomplish this safely is... annoying.
Hard to believe Ford dropped the ball on this with a vehicle completely designed around going off-road, overlanding, etc... but here we are. 🤷‍♂️
nwGTS
Nate
Chicago, IL
Right, now that I know this, replacing the inverter is another task to add to the list. Assuming it's in the rear console near the receptacle, hopefully there is enough space to simply swap it out for a higher quality (also more expensive) unit.
If you're open to it, I'd love to see what your research net here if you could post it up when you're ready.
