Bronco Halogen to LED tail lights - 4D Tech Programmer
Robs
Rob
New hampshire
2023 Black Diamond
Wondering if anyone has experience using this product to solve issues related to swapping Halogen tail lights for LEDs?
https://www.4dtech.com/bronco-tail-light-conversion-programmer/
I have a set of AlphaRex tail lights that are currently causing fast flash/flicker issues. Reading other threads it seems that no one has figured out how to solve the issue using Forcan, but maybe this 4D Tech Programmer is a solution?
Appreciate any thoughts.
Are we all saying that you can’t just buy LED tail light bulbs or back up bulbs and put them in place of the halogen’s without having to reprogram the car?
fishercat14
Jack
Connecticut
Ford Bronco
I'm sure you'd need FORSCAN.
I spoke to 4D Tech - only works with Oracle lights, which I don't really understand.
jsoa
Jose
Delaware
2024 Bronco 4dr
I actually had 4D tech make these. Essentially it should make any vehicle like a halogen equipped Bronco. It will ignore the extra wire in the tails that is present with LED models.
So as long as the tails you buy work fine with vehicles that have halogen tail lights, it should work fine after using this on an originally equipped LED tail vehicle.
can you get them to make one that garunteed to work with morimoto taillights? I'd buy in that case.
Robs
Rob
New hampshire
2023 Black Diamond
That’s just CRAY. TOO PROPRIETARY!
