Bronco coilover spring specs?
Silver-Bolt
Eureka, MT
Out of the box:
Fox
Front: 16.55 X 3.630, 365lb
Rear: 15.5 X 3.57, 185 LB
King
Front: 16.00” x 3.00x 550lb
Rear: 4.00” x 3.00 500lb / 14.00” x 3.00x 350lb
Awesome! Thank you!
87-Z28
Andy
BMW
Here are some spring rates from @Snacktime bilstein 5100s thread. Some fairly soft springs.
Here are the specs comparing the Bilsteins/OME. The Bilstein 6112 fronts sit between the OME medium and heavy, and the rears match the medium OME springs.
Ok
87-Z28
Andy
BMW
Not the same application but My old FJ Cruiser factory springs were 500lb. Went up to 650's for a heavy bumper and winch.
I think that one of the differences with the Bronco may be the motion ratio of the LCA. Bronco has a small wheel amplification from shock travel. Probably only about 1.5. My earlier calculations in this thread did not account for that. Load at the wheel should be multiplied by this factor to get spring load in the shock for the front end. So I believe my earlier spring rate estimates are a little low.
the FJ cruiser may have a larger motion ratio. Maybe closer to 2.0. Given similar vehicle weights it might then need larger spring rates. By a factor of 2/1.5 or 1.33. So a 500 fj cruiser spring might be equivalent to a 375 bronco spring. Maybe that is one reason the front spring rates seem lower. Just a thought. Any idea what the motion ratio for FJ cruiser is?
87-Z28
Andy
BMW
Some lessons learned. Thanks @Silver-Bolt for input. So I think it is a challenge to measure displacements on truck and estimate spring forces accurately. Weight distribution and CG are not really known. So load on a wheel is difficult to get. Gravity and an incline also have an effect. In the IFS, motion ratio can not be ignored in the front. Too many sources of error.
Perhaps the best way is to use the linear spring theory. K= G * d^4 / (8 * N * D^3) for a gut check, using this on OME data, d=15.75 mm=0.62”, N=10.5, G=11x10^6 psi, K=332, so coil diameter calculates as D=3.9. Table doesn’t list coil diameter so can’t calculate K directly. Table does list spring weight (5.2) kg, so coil diameter can also be calculated from weight as 4.0”. Very similar to 3.9” from spring theory. Fox coil diameter was reported as 3.6” for front. Ford springs have a fairly large diameter at about 5.5” and don’t sit as snuggly on the shock as OME or fox.
Seems that the spring theory works fairly well for the OME springs. So from earlier calculations, the Ford spring rates from my 4dr 2.3 OBX hitachis calculated as:
  • Front 350 lbs/in
  • Rear 225 for initial linear range
I now believe those are pretty good numbers. SAS springs are likely heavier to achieve additional lift and not affect either preload or usable extension travel.
IFS motion ratios. PIA… For bronco this seems to be close to 1.5 for the front. Close to 1:1 in the back. So if rear spring rate is 225 then a similar rate spring on front would need to be 225*1.5 or 340. The Bronco spring rates calculated above then seem fairly balanced on all four corners.
Silver-Bolt
Eureka, MT
  • Front 350 lbs/in
It would be super simple if I had factory springs to put in our spring rate machine. No guessing/speculating required. I will be adding a fair amount of weight to my Wildtrak when it arrives. ARB Summit bumper, winch, Metal-Tech rock rails, skid plates, and rear bumper with swingout tire carrier. I don't want a lift, I just want to handle the extra weight at the factory ride height.
Bikeric
Tulsa
2022 Badlands LUX on 37's
The unfortunate thing would be you need to test 11 different front springs and 6 different rear springs. :whistle:
All springs lengths should be the same for front, and again for rears. The heaviest spring rate would have to be from a 4-door First Edition as it had EVERY OPTION. Find someone with a 4-door FE and ask for their VIN so you can determine what spring P/N they have.
(I grabbed this VIN from BaT: 1FMEE5EP2MLA40056 )
Ford Bronco Bronco coilover spring specs? GhDVDXh
87-Z28
Andy
BMW
Guessing and speculation is part of the fun. 😁
agreed on the testing. The simplest would be to test the springs from heaviest and lightest trims. Then weight ratios could be used to get all the rest.
I would send mine but $60 in shipping for ground ups and I want them back. Surely someone close to you has replaced their coilovers.
Ford Bronco Bronco coilover spring specs? 1B25095D-C891-4D2B-AA6C-A775FF9EE6AD
Silver-Bolt
Eureka, MT
Local would be ideal. No problem to return the springs after testing. Testing is completely non-destructive. The machine just compresses the spring and measure the rate at specified compression lengths.
87-Z28
Andy
BMW
Understood. I have tested concrete and metal samples in axial compression and tension. Both non destructively and to failure. The testing would also provide the nonlinear response of the rear spring as displacement increases. If I was within 500 miles of you I would bring mine and watch. Awesome stuff.
I am moving my daughter to Seattle in January. If we don’t have numbers by then I may stop by. 😂
87-Z28
Andy
BMW
Out of the box:
Fox
King
can you also share the preload in inches that fox is using on the front out of box at lowest setting. Or whatever setting they use when advertising 3” of lift over stock SAS.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
I don't have those specs to share at the moment. We will be putting together a very detailed tech article, it's just going to take some time.
TheGOAT
Mo
Qatar
Bronco Raptor
  • Front 350 lbs/in
Reviving this thread back from the dead since I was looking for some stock spring rate numbers and noticed some errors.
Im surprised that you forgot to incorporate front motion ratio when estimating front spring rate by means of spring deflection.
Also the correct formula for wheel rate = spring rate x (motion ratio)^2.
So in the previous example, if the rear spring is 225lbs, assuming a 1:1 motion ratio, then the equal front spring would be 506lbs assuming a 1.5:1 MR.
87-Z28
Andy
BMW
indeed. Some poor assumptions that have already been highlighted in some of the earlier posts.
However the stock front springs are definitely lighter than 506 lbs/in. Especially the non-SAS flavors.
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I've disassembled the Fox shocks on the Hoss 3.0 suspension on my Wildtrak to install a spring perch collar and I'd doubt they're more than 300 lb/in up front.
GPPBronco
Detroit
linktr.ee
‘23 Toyota 4Runner TRD Off Road
I haven't seen specs, but I have put stock springs from a heavier trim on my shocks and it firmed up the ride and gave lift. I highly recommend it.
Bumping an old thread to avoid creating a new one.
I have a base 2dr, 2.3L with the added weight of a front winch/mount, and OEM skid plates. Any shots in the dark which front springs (which 6G trim?) would be a good swap to level it out a bit? It makes more sense to me to swap heavier springs instead of adding front lift spacers. Here is what I’m starting with:
Ford Bronco Bronco coilover spring specs? IMG_4823
