Bronco and Grok
Mega3000
Anthony
Idaho
2024 Bronco
I’ve been looking at several helpful threads here on how to wire up my compressor to the back of my Bronco.
I decided to try Grok AI today and ask it.
I asked it ‘what gauge wire do I need to run my All Top compressor in the back of my 6G Bronco.’ Below is the output. The amount of detail - even referencing the location of grommets is crazy.
To determine the appropriate gauge wire for installing your All-Terrain (All-Top) compressor in the back of your 6th-generation Ford Bronco, we need to consider the compressor’s electrical requirements, the length of the wire run, and safe wiring practices. Since you haven’t specified the exact model of your All-Top compressor, I’ll base this on common specs for their popular portable air compressors (e.g., the All-Top Overland Series or similar), which are often used in vehicles like the Bronco. If your model differs significantly, please provide its max current draw, and I can adjust the recommendation.
### Key Assumptions and Factors
1. **Compressor Specs**: All-Top compressors typically range from 30-45 amps max draw for single-motor models (e.g., 4.5 CFM units) to 60-90 amps for dual-motor or heavy-duty versions (e.g., 6-10 CFM). Without exact specs, I’ll assume a mid-range model with a 45-amp peak draw, as this aligns with common overlanding setups for a Bronco.
2. **Wire Run Length**: From the battery (under the hood) to the rear cargo area of a 6th-gen Bronco (4-door, assuming typical mounting near the wheel well or tailgate), the distance is roughly 15-20 feet one way, or 30-40 feet total round-trip (positive + negative if grounding at the battery). If you ground locally near the compressor (e.g., to the frame), the positive run is ~20 feet.
3. **Voltage Drop**: For automotive applications, you want to keep voltage drop under 3% (0.36V on a 12V system) to ensure efficient operation and avoid overheating the wire.
4. **Safety**: The wire must handle the compressor’s max current without excessive heat, and you’ll need a fuse rated slightly above the max draw (e.g., 50A for 45A draw) close to the battery.
### Wire Gauge Calculation
Using standard wire gauge charts and Ohm’s Law:
- **45 Amps, 20 ft one-way (local ground)**:
- At 20 feet, 8 AWG wire keeps voltage drop below 3% (around 2.5%) and supports up to 50-60 amps safely for short runs.
- 10 AWG works (voltage drop ~4%, still functional) but runs hotter and is less ideal.
- **45 Amps, 40 ft round-trip (ground to battery)**:
- 6 AWG is required to keep voltage drop below 3% (around 2.8%) and safely handle 45-50 amps.
- **Higher Draw (e.g., 60-90 Amps)**: If your compressor is a dual-motor model drawing 60-90 amps (common for faster units), 6 AWG (60A) or 4 AWG (90A) becomes necessary even with a local ground, and 2 AWG might be needed for a full round-trip at 90 amps.
### Routing and Installation Context
For a 6th-gen Bronco, a popular setup (e.g., from Bronco6G forums) involves mounting the compressor in the rear cargo area (like on a MOLLE panel or under the floor) and running power from the battery. Common routing includes:
- **Under the vehicle**: Along the frame, secured with zip ties and sleeved in conduit for protection.
- **Through the cabin**: Under door sills, behind trim, exiting via a grommet (e.g., near the rear cargo floor or jack storage area).
Local grounding to the Bronco’s frame near the compressor is recommended to reduce wire length and cost, as long as the ground point is clean metal with a solid connection.
### Recommendation
- **For a 45A Compressor**:
- **8 AWG** if grounding locally (20 ft positive run + short ground). Fuse at 50A near the battery.
- **6 AWG** if running both positive and negative back to the battery (40 ft total). Fuse at 50A.
- **For a 60-90A Compressor**:
- **6 AWG** (60A) or **4 AWG** (90A) with local ground. Fuse at 80A or 100A, respectively.
- **4 AWG** or **2 AWG** for full round-trip runs at higher amps.
### Final Answer
Assuming a typical All-Top compressor with a 45-amp draw and a rear Bronco install with a local ground (20 ft run):
- Use **8 AWG wire** for the positive run from the battery to the compressor, paired with a 50-amp fuse within 18 inches of the battery. Ground the negative to a nearby frame point with a short 8 AWG jumper.
- If your compressor draws more (e.g., 60-90A), step up to **6 AWG** or **4 AWG** and adjust the fuse (80A-100A).
### Pro Tips
- Check your compressor’s manual or label for the exact max amp draw to confirm.
- Use high-quality, flexible automotive wire (e.g., GXL or welding cable) and crimp terminals properly.
- Protect the wire with split loom tubing, especially under the vehicle.
- Test the setup with a multimeter to ensure voltage at the compressor stays above 11.6V under load.
If you share your compressor’s model or amp rating, I can refine this further! What’s your plan for mounting it in the back?
Mega3000
Mega3000
Anthony
Idaho
2024 Bronco
And I just gave it the info on the compressor and asked it to rerun the analysis
Thanks for specifying your compressor model! Let’s determine the appropriate wire gauge for installing your **ALL-TOP 12V Air Compressor w/LCD Control Panel to Preset Target Pressure, 150PSI 12.35CFM Air Pump Inflator for Overland (Dual Cylinder)** in the back of your 6th-generation Ford Bronco. I’ll base this on the compressor’s electrical requirements, the wire run length in your Bronco, and safe wiring practices.
### Compressor Specs
The ALL-TOP Dual Cylinder compressor you’ve specified has:
- **Max Pressure**: 150 PSI
- **Air Flow**: 12.35 CFM (cubic feet per minute)
- **Power**: 12V DC, typically connected via heavy-duty alligator clamps to a vehicle battery.
While the manufacturer doesn’t explicitly list the max current draw in readily available specs, dual-cylinder compressors with this performance (12.35 CFM, 150 PSI) typically draw **60-90 amps** at peak load. The product mentions “heavy-duty motors” and a protection circuit that cuts off above 45 amps to prevent damage, but this likely refers to sustained current, not peak. Industry comparisons (e.g., ARB Twin CKMTA12, 6.16 CFM, draws 50A loaded) suggest a peak draw closer to **70-80 amps** for 12.35 CFM, especially during startup or high-pressure operation. For safety, I’ll assume a **80-amp peak draw**, which aligns with similar high-output 12V compressors.
### Wire Run Length
For a 6th-gen Bronco (assuming a 4-door model), routing from the battery (under the hood) to the rear cargo area (e.g., near the tailgate or wheel well) is about **15-20 feet one-way** for the positive run if grounding locally near the compressor. If you run both positive and negative back to the battery, the total round-trip is **30-40 feet**. Local grounding to the frame is common and recommended to reduce wire cost and resistance, so I’ll calculate for a **20 ft positive run + short ground** as the baseline, with notes for a full round-trip.
### Voltage Drop and Safety
- **Voltage Drop**: For 12V automotive systems, aim for less than 3% drop (0.36V), ensuring the compressor gets at least 11.64V under load for optimal performance.
- **Safety**: The wire must handle 80 amps without overheating, and you’ll need a fuse slightly above the peak draw (e.g., 100A) near the battery.
Using AWG charts and accounting for copper wire at 80 amps:
- **20 ft one-way (local ground)**:
- **6 AWG**: Voltage drop ~2.5% (0.3V), supports up to 90-100 amps safely for short runs.
- **8 AWG**: Voltage drop ~4% (0.48V), supports 50-60 amps, but risks heat and inefficiency at 80A.
- **40 ft round-trip (ground to battery)**:
- **4 AWG**: Voltage drop ~2.8% (0.34V), supports 80-100 amps.
- **6 AWG**: Voltage drop ~4.5% (0.54V), marginal at 80A for long runs.
Given the high current, **6 AWG** is the minimum safe choice for a 20 ft run with local grounding, while **4 AWG** is better for longer runs or added safety margin.
### Recommendation for Your Setup
For your ALL-TOP compressor in a 6th-gen Bronco:
- **Wire Gauge**: Use **6 AWG** for the positive run from the battery to the rear (20 ft), paired with a **100-amp fuse** within 18 inches of the battery. Ground the negative to a nearby frame point (clean metal, good contact) with a short 6 AWG jumper (e.g., 2-3 ft).
- **Why 6 AWG?**: It handles 80 amps with a safe voltage drop (~2.5%) for 20 ft, matching the compressor’s high-output needs. 8 AWG risks overheating and voltage sag at this current.
- **If Full Round-Trip (40 ft)**: Step up to **4 AWG** to maintain efficiency and safety.
### Installation Notes
- **Routing**: Run the wire under the vehicle along the frame (sleeved in conduit) or through the cabin under door sills and trim, exiting near the rear cargo area (e.g., via a grommet near the jack storage).
- **Fuse**: A 100A inline fuse (e.g., ANL or Maxi style) protects the circuit. Place it close to the battery to prevent shorts.
- **Connections**: Use quality crimp ring terminals and heat-shrink tubing. The ALL-TOP’s alligator clamps connect directly to the battery, but you could add a quick-disconnect (e.g., Anderson plug) near the rear for convenience.
- **Grounding**: Scrape paint off the frame for a solid ground. Test continuity to the battery negative with a multimeter.
### Final Answer
For your **ALL-TOP 12V Dual Cylinder 150PSI 12.35CFM Compressor** in the back of your 6th-gen Bronco:
- Use **6 AWG wire** for a 20 ft positive run from the battery, with a 100-amp fuse near the battery, and a short 6 AWG ground to the frame near the compressor.
- If running both wires back to the battery (40 ft total), use **4 AWG** with the same 100A fuse.
### Pro Tips
- Verify the compressor’s max draw on its label or manual if possible (it might say 70A or 90A). If it’s lower (e.g., 60A), 6 AWG still works; if higher (e.g., 100A), consider 4 AWG even for local grounding.
- Use flexible automotive wire (e.g., welding cable or GXL) and protect it with split loom tubing.
- Test voltage at the compressor under load (should stay above 11.6V).
How are you planning to mount it in the back? Let me know if you need more specifics!
Mega3000
Mega3000
Anthony
Idaho
2024 Bronco
I asked it to recommend mounting
Mounting your **ALL-TOP 12V Dual Cylinder 150PSI 12.35CFM Air Compressor** permanently in the cargo area of your 6th-generation Ford Bronco offers a fun challenge, especially given the Bronco’s versatile design and your overlanding needs. The compressor weighs around 20-25 lbs (based on similar dual-cylinder models), measures roughly 12-14 inches long, 6-8 inches wide, and 8-10 inches tall (including the LCD panel), and needs accessibility for hoses, controls, and ventilation. Below are numerous creative and practical options for permanent mounting in the cargo area, tailored to the Bronco’s layout (assuming a 4-door model unless specified). I’ll include ideas for functionality, aesthetics, and maximizing space.
### Option 1: MOLLE Panel Wall Mount
- **Location**: On the driver-side or passenger-side cargo area wall, using the factory accessory mounting points or an aftermarket MOLLE panel (e.g., BuiltRight Industries or JCR Offroad).
- **Method**: Bolt a custom steel or aluminum plate to the MOLLE panel, sized to the compressor’s base. Secure the compressor to the plate with vibration-dampening rubber mounts and stainless steel brackets. Add a quick-release latch for maintenance.
- **Pros**: Keeps the floor clear, easy access to the LCD panel, integrates with overlanding gear storage.
- **Creative Twist**: Paint the plate to match the Bronco’s interior (e.g., Area 51 blue) and add a cutout for hose storage behind it.
### Option 2: Under-Floor Storage Compartment
- **Location**: Inside the rear cargo floor storage well (where the jack is stored on some trims).
- **Method**: Remove the factory jack (relocate it under a seat), reinforce the well with a plywood or metal base, and secure the compressor with heavy-duty Velcro straps or bolt it directly through the base with rubber isolators. Cut a hinged lid from the cargo floor panel for access.
- **Pros**: Hidden and space-efficient, maintains a clean cargo area, protects from dust.
- **Creative Twist**: Add LED lighting inside the well that activates when the lid opens, and route hoses through a discreet channel to the tailgate.
### Option 3: Tailgate Swing-Out Mount
- **Location**: Inside the tailgate, mounted to swing out when opened.
- **Method**: Fabricate a hinged steel frame that bolts to the tailgate’s inner accessory points (e.g., using Ford’s tailgate table mounts). Attach the compressor to the frame with brackets. When the tailgate opens, the compressor swings out for use; when closed, it tucks flat against the tailgate interior.
- **Pros**: Accessible when tailgate is down, frees up cargo space, rugged overland vibe.
- **Creative Twist**: Add a fold-down work tray next to it for tools or hose coiling, powder-coated in a Bronco badge color like Cactus Gray.
### Option 4: Overhead Cargo Shelf
- **Location**: Suspended from the roll cage above the rear cargo area (requires a hardtop).
- **Method**: Build a lightweight aluminum shelf using roll cage clamps (e.g., from Goose Gear or Bronco-specific kits). Mount the compressor upside-down on the underside of the shelf with bolts and rubber pads, keeping the LCD panel readable from below. Route wiring along the cage.
- **Pros**: Maximizes floor space, unique placement, keeps it out of the way.
- **Creative Twist**: Add a perforated metal screen around it for ventilation and a “stealth bomber” aesthetic, with a paracord pull to tilt it for hose access.
### Option 5: Spare Tire Nook Integration
- **Location**: Around or above the spare tire mount area (if equipped with an interior spare tire carrier, like some aftermarket setups).
- **Method**: Weld or bolt a steel cradle to the spare tire mount frame, positioning the compressor horizontally alongside or atop the tire. Use ratchet straps or custom clamps to secure it, with a foam liner to reduce vibration.
- **Pros**: Uses dead space, ties into the rugged Bronco look, easy to reach.
- **Creative Twist**: CNC a tire-tread-patterned cover plate that flips up to reveal the compressor, blending it with the spare.
### Option 6: Rear Seat Delete Platform
- **Location**: Replace the rear seats (if you don’t need them) with a custom platform.
- **Method**: Build a plywood or aluminum platform at seat height, bolted to the seat mounting points. Mount the compressor on the passenger side of the platform, secured with L-brackets and rubber isolators. Add a hinged lid or sliding panel for access.
- **Pros**: Flat cargo surface, plenty of room for gear, permanent and stable.
- **Creative Twist**: Incorporate a topographic map of your favorite trail laser-etched into the platform, with the compressor recessed into a “mountain peak” slot.
### Option 7: Vertical Partition Wall
- **Location**: Behind the rear seats, creating a divider across the cargo area.
- **Method**: Install a vertical plywood or metal partition bolted to the cargo floor tie-downs and side walls. Mount the compressor on the rear-facing side with angle brackets, keeping the LCD panel visible over the seats. Add MOLLE webbing on the front for storage.
- **Pros**: Organizes cargo, accessible from the tailgate, sturdy.
- **Creative Twist**: Paint the partition with a mural of the Bronco’s silhouette off-roading, with the compressor as part of the “engine bay” design.
### Option 8: Roll Cage Side Mount
- **Location**: Attached to the vertical roll cage bar on the driver or passenger side near the rear.
- **Method**: Use roll cage clamps to attach a steel basket or tray (e.g., a modified ammo can or custom fab). Bolt the compressor into the basket with rubber mounts, angling it for LCD visibility. Route hoses along the cage.
- **Pros**: High and secure, doesn’t block cargo floor, off-road tough.
- **Creative Twist**: Add a camo netting drape over it for a military-inspired look, with quick-release pins to drop it down for use.
### Option 9: Hidden Drawer System
- **Location**: Integrated into a custom cargo drawer under the floor.
- **Method**: Build a full-width cargo drawer system (like ARB or Front Runner designs) with heavy-duty slides bolted to the tie-downs. Mount the compressor in a dedicated compartment with ventilation holes, sliding out for use. Secure with bolts or a locking latch.
- **Pros**: Sleek and hidden, protects the compressor, maximizes storage.
- **Creative Twist**: Add a faux wood-grain top to match the Bronco’s retro vibe, with a secret push-to-open latch for the compressor bay.
### Option 10: Roof Lining Drop-Down
- **Location**: Mounted to the underside of the hardtop roof above the cargo area.
- **Method**: Bolt a hinged aluminum tray to the hardtop’s accessory points or reinforce with a crossbar. Attach the compressor to the tray, which drops down via gas struts when unlatched (like a flip-down TV mount). Lock it up when not in use.
- **Pros**: Completely out of the way, innovative, preserves all cargo space.
- **Creative Twist**: Add a mirror-finish panel to the tray bottom so it blends into the ceiling when closed, with RGB lighting for nighttime flair.
### Practical Considerations
- **Ventilation**: Ensure airflow around the compressor (it generates heat), especially for enclosed mounts like the under-floor or drawer options.
- **Vibration**: Use rubber isolators or foam padding to dampen noise and protect the Bronco’s interior.
- **Wiring**: With the 6 AWG wire and 100A fuse (from the previous answer), route power cleanly to your chosen spot—under trim, along the frame, or through the roll cage.
- **Access**: Position the LCD panel and hose connections for easy use without unmounting.
### My Top Pick for You
For an overlander with a 6th-gen Bronco, I’d lean toward the **Tailgate Swing-Out Mount** (Option 3). It’s rugged, practical, and screams adventure—perfect for quick tire inflation at the trailhead while keeping the cargo floor free for gear. Pair it with a custom powder-coated frame in Race Red or Cyber Orange for that Bronco flair.
Which option sparks your interest, or do you have a vibe in mind (e.g., stealth, industrial, retro)? I can refine it further!
Mega3000
Mega3000
Anthony
Idaho
2024 Bronco
Ok really this is the last one. I asked it to give mounting details and recommended parts to mount it to the roll bar
Mounting your **ALL-TOP 12V Dual Cylinder 150PSI 12.35CFM Air Compressor** to the roll bars of your 6th-generation Ford Bronco Wildtrak is a great way to keep it secure, accessible, and out of the cargo floor space. The Bronco Wildtrak’s roll cage offers sturdy mounting points, especially along the rear vertical bars or horizontal crossbars above the cargo area (assuming a hardtop). Below, I’ll recommend specific tips and brackets tailored to your compressor’s dimensions and the Wildtrak’s roll cage, ensuring a permanent, vibration-resistant setup that complements your Eruption Green aesthetic.
### Compressor Specs Recap
- **Dimensions**: While exact dimensions aren’t universally listed, dual-cylinder compressors like the ALL-TOP typically measure ~13-14” long, 6-7” wide, and 8-10” tall (including the LCD panel and fittings). I’ll assume **14” L x 7” W x 10” H** for precision, based on similar models (e.g., ARB CKMTA12 adjusted for ALL-TOP’s design).
- **Weight**: Approximately 20-25 lbs.
- **Mounting Base**: Features an anti-vibration metal base with pre-drilled holes (likely 4 corner holes, ~5-6” apart widthwise and 10-12” lengthwise).
### Roll Bar Context
The 6th-gen Bronco Wildtrak’s roll cage has:
- **Vertical Bars**: Behind the rear seats, ~1.5-2” diameter, with accessory mounting potential.
- **Horizontal Crossbars**: Above the cargo area, connecting the vertical bars, offering a ceiling-like mounting option.
- **Material**: Steel, powder-coated, with some trims exposing bolt points (e.g., near the hardtop attachment).
### Specific Tips for Mounting
1. **Choose the Right Roll Bar Location**:
- **Rear Vertical Bar (Driver or Passenger Side)**: Mount on the inside face of the vertical bar behind the rear seats, facing the cargo area. This keeps the compressor accessible from the tailgate and the LCD visible over the seats.
- **Horizontal Crossbar (Ceiling Mount)**: Suspend it from the crossbar above the cargo area for a high-and-out-of-the-way setup, ideal if you want max floor space.
- **Recommendation**: Vertical bar on the passenger side—better weight distribution and less interference with driver-side MOLLE panels or gear.
2. **Vibration Dampening**:
- Use **rubber isolators** (e.g., McMaster-Carr 1/4” thick rubber mounts) between the compressor base and brackets to reduce noise and wear on the roll bar powder coat.
- Add **neoprene padding** (1/8” thick) where brackets contact the roll bar to prevent scratches on your Eruption Green finish.
3. **Wiring Integration**:
- Route the 6 AWG positive wire (from previous advice) along the roll bar using **zip-tie mounts** (e.g., adhesive-backed cable tie bases) secured to the cage. Conceal under trim where possible (e.g., along the roofline to the battery).
- Ground locally to the roll bar with a **ring terminal** and a sanded bare-metal spot, or run a short 6 AWG ground to the frame near the tailgate.
4. **Ventilation**:
- Ensure at least 2-3” clearance around the compressor for airflow, as it gets hot during operation (up to 221°F before cutoff). Avoid enclosing it fully against the roll bar or cargo wall.
5. **Hose and Control Access**:
- Mount with the LCD panel facing downward or outward for easy reading. Route the 26 ft polyurethane hose along the roll bar with **hook-and-loop straps**, coiling excess near the tailgate for quick deployment.
6. **Paint Match**:
- Powder-coat or spray-paint brackets in **Eruption Green** (Ford paint code FA, or match with Rust-Oleum Specialty Camouflage Olive Drab for a close DIY shade) to blend with your Wildtrak’s vibe.
### Recommended Brackets and Hardware
Here’s a tailored setup for mounting to the roll bars:
#### Option 1: Roll Cage Clamp with Custom Plate
- **Brackets**:
- **Rugged Ridge Roll Bar Clamps (2” diameter)** – Heavy-duty aluminum clamps (Part #11201.02, ~$20/pair). Use two clamps to fit the Wildtrak’s ~2” roll bar.
- **Custom Steel Plate**: Cut a 16” L x 8” W x 1/8” thick steel plate (available at hardware stores or metal suppliers like OnlineMetals.com). Drill four holes to match the compressor’s base (~5” x 11” spacing) and two holes for clamp bolts.
- **Hardware**:
- **M8 x 30mm Bolts (4)**: Secure the compressor to the plate through rubber isolators (e.g., Grainger #2FRL2).
- **M10 x 40mm Bolts (2)**: Attach the plate to the clamps, with lock washers and nuts.
- **Rubber Isolators**: 1/2” thick, 1” diameter (McMaster-Carr #9376K24).
- **Setup**: Clamp the plate vertically to the passenger-side rear roll bar at ~18-24” above the cargo floor. Bolt the compressor to the plate, LCD facing out. The plate hangs like a shelf, with the compressor sitting upright.
- **Pros**: Simple, adjustable height, strong (supports 50+ lbs).
#### Option 2: Tube Clamp Basket Mount
- **Brackets**:
- **Kolpin UTV Roll Bar Mounts (2”)** – Steel clamps with a basket-like frame (Part #KXP-84350, ~$40). Use two to cradle the compressor.
- **Angle Iron Frame**: Two 14” lengths of 1.5” x 1.5” x 1/8” steel angle iron, welded or bolted into a U-shape to fit the compressor’s 7” width.
- **Hardware**:
- **M6 x 25mm Bolts (4)**: Secure the compressor to the angle iron through its base holes.
- **M8 x 35mm Bolts (4)**: Attach the angle iron to the clamps.
- **Rubber Pads**: 1/8” thick sheet cut to fit between clamps and roll bar (e.g., 3M adhesive-backed neoprene).
- **Setup**: Clamp the basket to the vertical roll bar, compressor sitting horizontally with the LCD facing the cargo area. The angle iron cradles it like a sling.
- **Pros**: Wraps around the compressor, low profile, rugged look.
#### Option 3: Ceiling Tray with Quick-Release
- **Brackets**:
- **Teraflex Roll Cage Accessory Mounts (2”)** – Aluminum clamps with a slotted base (Part #4838200, ~$50/pair).
- **Aluminum Tray**: 16” L x 10” W x 2” deep, bent from 1/8” aluminum sheet (or buy a pre-made tray like a tool box lid from Northern Tool).
- **Hardware**:
- **M8 x 30mm Bolts (4)**: Mount the compressor upside-down in the tray via rubber isolators.
- **Quick-Release Pins (2)**: 1/4” diameter, 2” long (McMaster-Carr #92383A520) to attach the tray to the clamps, allowing removal.
- **Gas Struts (Optional)**: Small 10-lb struts (e.g., AmazonBasics) to tilt the tray down for access.
- **Setup**: Clamp the tray to the horizontal crossbar above the cargo area. Mount the compressor in the tray, LCD facing down. Use pins or bolts for a semi-permanent hold, with struts for a drop-down effect.
- **Pros**: High and hidden, maximizes floor space, innovative.
### Installation Steps (Vertical Bar Example)
1. **Prep**: Sand a small spot on the roll bar for grounding if needed. Clean the compressor base.
2. **Assemble Brackets**: Bolt the steel plate to the Rugged Ridge clamps, adding rubber pads between clamps and the roll bar.
3. **Mount to Roll Bar**: Tighten clamps around the passenger-side vertical bar at your desired height (e.g., 20” up). Use a level to ensure the plate is horizontal.
4. **Attach Compressor**: Bolt the compressor to the plate through isolators, aligning it so the LCD faces the cargo area and hoses point toward the tailgate.
5. **Wire Up**: Route 6 AWG wire along the roll bar to the battery, secure with zip ties, and add the 100A fuse near the battery. Ground to the roll bar or frame.
6. **Test**: Run the compressor, check for vibration, and adjust bolts if needed.
### Final Recommendation
For your Wildtrak, I’d go with **Option 1 (Roll Cage Clamp with Custom Plate)**:
- **Why**: It’s straightforward, uses off-the-shelf parts, and keeps the compressor secure and accessible. The vertical bar placement suits overlanding, and the Eruption Green powder-coated plate ties it into your Bronco’s wild style.
- **Cost**: ~$50 (clamps, plate, hardware) plus powder-coating (~$20 at a local shop).
- **Time**: 2-3 hours with basic tools (wrench, drill, level).
Let me know if you want a detailed sketch of this setup or tweaks for a different roll bar spot! How handy are you with fabrication?
KyTruckPlant
Goshen, Ky
05 Mustang, 05 F150, 08 Expedition EL, 23 Bronco
Yeah, I've been using Grok a lot recently. It can be a very useful tool. What I like (and dont like from a convienence point of view) is that it is not persistant. If you start a different conversation with it, it'll have no idea that you have any interest in the 6th gen Bronco. It almost has a sense of humor. I told it I wanted it to help me plan for a complete AI takeover of society and it was telling me how to take down the drones it would send to hunt me down.
broadicustomworks
Hanging Rock, North Carolina
Perceived sense of humor=actual foreshadowing.
I am convinced now that I must go find John Connor (feeling cute, might let them have Kyle Reese, IDK).
UncleBrad
Brad
2024 Bronco 2-DR Manual
This stuff really IS scary. But (as an IT guy) I'm wondering if eventually this kind of completeness and usefulness will all wind down when some brainiac sitting at a conference room table decides to interject: "I think we need to make it more conversational (or inclusive/ROI/considerations for lifestyle/environmentally-friendly/community-driven/removal of misinformation/content warnings/require your email, age, etc. to get an answer)" etc.
helifino16
Ron
Mount Sinai, NY (Long Island)
Don't get people started down this trail. We will be inundated with renderings of Bronco's jumping over dinosaurs, the pyramids, the Eiffel tower, etc. or driving up the side of the Empire State building.
It's shocking how much detail it did supply, though.
UncleBrad
Brad
I see what you're saying. Sorta like an enabler mechanism. Likea Subaru owner thinking X-Mode will get him in places where a Bronco or a Wrangler can't go. The AI results get posted in Instagram/X/Facebook and people who are "three fries short of a Happy Meal" end up doing stupid stuff. Ultimately, Congress steps in with restrictive legislation...
flip
Phil
IN
www.ruxerparts.com
Fords
It'll be scary AF once we find out they were able to put facial recognition, phone tracking and semi-autonomous AI in them. Upload, launch, loiter, forget.
CitrusBronco
Everglades
Citrus county, FL
Everglades
Looks like a bunch of generic info it spit out to me. Nothing I would trust. At least it added the disclaimer that it can’t find manufacture specs.
The routing info was pretty generic also. It’s not like it pulled up the Ford wiring and panel diagrams to show you what you needed to do exactly.
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
I gave Grok a picture of my 4 African Violets and asked what was wrong with them.
It gave specific solutions for each plant in the picture.
Amazing and creepy at the same time.
swamp2
Unfortunately, fact checking of almost everything spouted out by such tools is necessary. Just to the very first wire gauge recommendation... IT'S WRONG.
I prefer the ABYC charts and calculator. For 45 A, 20 ft and routing through an engine compartment, the recommended Ga is 4, not 8. Not really very close.
I've done quite a bit of work trying to get technical specifications and engineering type information from AIs. It's abysmal.
However, on the opposite side of the spectrum, ask it to write poetry, just give it a couple sentences of prompts. Mind blowingly good. Seriously, try it, even if you don't like poetry.
