BaseSquatch
@NotOJsBronco
Seems like only the 2.7L is having problems.
rutherk1
Keith
Ohio
2021 Bronco Badlands 4 door Manual
At the end of the day, vehicles are built with stuff that humans (evolved apes) dug out of the ground. It's truly amazing that it ever works. Probably a bad module. It will get fixed. Nothing Ford or Bronco specific. Just nature of the beast. Even if you build at 99.9% perfect (which seems good) you will still have 100 failures in 100,000 units.
Good luck. I had an early 2011 6.7. Same kind of stuff. It all got sorted.
PartyMarty
Marty
2016 Jeep Wrangler Black Bear, 2009 VW Rabbit
So an annoying but erroneous code pops up but is cleared, and then an airbag issue happens? I don’t see how the airbag and 2.7 engine are related 🤷🏼‍♂️
FourHorses
Four Ford Horses and an Expedition
I don't think that's anyone's logic, at least its not mine. Just a potential common denominator at this point.
flip
Phil
IN
www.ruxerparts.com
Fords
Everything is networked and has multiple modules exchanging info with each other. One module could have a parameter range setting that another is looking at and conflicts with what it thinks it should be. Networking issues are some of the most difficult electrical issues to diagnose because there is sooooo many related systems. You may get lucky and find a pin fit problem in a connector causing an intermittent concern or you could go through all of the pin point tests and find out Ford has a programming issue there is currently no fix for.
On it's face, the two post cat codes would indicate the converters are bad and not cleaning up the exhaust. First thing to do after checking codes would be to look at the connectors and terminals to make sure they are fully seated and there isn't damaged wiring. If all of that's good then the fun work starts.
Ford Bronco Bronco 2.7L issues - CEL codes and airbag warning light 1627567826972
mkennedy009
Portland, OR
2012 Triumph Bonneville T100 110th Anniversary
OP, I am glad you still have your humor.
Matthew
Matthew
Brighton, IL
66 Bronco, 77 Bronco, 04 F150, 15 Expedition
I also was told they would call me first thing this morning to let me know if the wiring would be today. As of an hour ago I haven't heard from them yet, but at least I am staying busy at work, and I am in no way compulsively checking my phone, email, and bronco6g :)
BroncoTodd
Todd
Redondo Beach, CA
Tesla Model X 100D
Sorry to hear about your troubles. Hope that at least the Escape was also Cyber Orange :p
desibull
Mahesh
Chandler, AZ
BMW 335i
Oh jeez....
Matthew
Matthew
Brighton, IL
Ford service advisor here. Regarding the lean codes, sounds like you may have run it low on fuel. Owners manual directs to fill at a quarter tank, if your light comes on you’re lower than you want to be. Just my .02
Yeah I was down on empty with the computer telling me I had 25 miles to go, so I was absolutely below a quarter tank when the light came on. This was the very first time I had to put fuel in it.
BroncoAgain
La Verne, Calif
2022 Gladiator Rubicon, Ram 2500 6.7 4x4
Sadly, this is just the beginning of these type of threads. The Bronco is a laptop with wheels. I don't recall hearing of any problems with the Bronco's that did any of the testing. Like KOH and all the other off road tests. I don't remember my '70 Bronco ever having a CEL and I beat the crap out of it.
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
So realistically, the 2.7 4-door has only 280 mile range, then?
Matthew
Matthew
Brighton, IL
Yeah I usually drive my 18 year old F150 until the low fuel light comes on before I stop and fill it up. Had been doing the same with the Expy until the price of fuel went back up, now I can't even use pay at the pump in town to fill it up because the pump shuts me off a $90 before the 34 gallon tank is full!
