Broken Rear Brow
Mett22
Armett Johnson
Los Angeles
Ford Bronco 2022
Hi Guys,
Took off my soft top then my "Rear Bow" snapped. Super weird. Took it to Ford Galpin and they said I had to replace the whole thing, which cant be right. Also said it would cost north of $21,000. Which i think is Ridiculous because it is such a small part. I just need to replace this corner piece right? New to the off road vehicle life. Please help!!
Ford Bronco Broken Rear Brow Screen Shot 2023-08-09 at 11.33.32 AM
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Only $21K
Area51BS
Ron
Badlands non SAS 4dr 2.3
Plenty for sale online or structural epoxy that back together first!
Mett22
Mett22
Armett Johnson
Los Angeles
Ford Bronco 2022
Can you direct me to the website? I have looked and having trouble finding any.
CM81
NA
did they mean $21. That makes far more sense. If not, go to another dealer because they obviously have no idea what they are talking about unless they are trying to severely rip you off
flip
Phil
IN
www.ruxerparts.com
Fords
Do you have lift struts installed? The failures I've seen is from too much "up" tension on the top and you have to slam it down harder to overcome the tension. The corners are super weak cast aluminum and not repairable.
Area51BS
Ron
Definitely try another dealer first. If not. Try this group. Be careful of scams. If you can’t pick it up it’s a scam and never pay first or at the very least use PayPal and make sure seller sends invoice for hoods or services to be protected. Don’t just use the send money option. Scammers will also try to sway you away from PayPal.
https://m.facebook.com/groups/404482794503523/
Area51BS
Ron
Someone could machine quality corners for far less than 21k
Mett22
Mett22
Armett Johnson
Los Angeles
Ford Bronco 2022
M2DZ-7851501-C $590.42 Should be covered by 3/36 unless obvious abuse.
Thank you so much this helped a lot.
Pseudoko
Vince
Chino, CA
My 2 Feet
16-21k is the current price for the entire soft top if you were to buy it part by part and include dealership labor. You just need that part that snapped that people have screen shotted.
later … probably way later when the soft top is available as an accessory it’ll probably be about 4500 is my guess.
