Braptor Front Tow Tab Removal?
Johnkn
Maryland
'66 GT350, 68.5 CJ Mustang, B2, Viper, Pantera,TRX
Tonight I removed the front lower front plastic cover and the skid plate on my '24 Braptor in order to prep for (black) paint tomorrow. I planned to paint the (2) front tow tabs as well and thought I'd remove them. On the left side, I removed 2 of the long bolts and when I had the 3rd about half way out the entire bumper dropped a little on that side which I didn't expect but now understand that the bumper is partially held in place with those 6 bolts. On the tow tab I was working on, even through 2 bolts were out and the 3rd was half way out and loose, the tab was still tight and wouldn't budge. How are they held in place? If a PITA to remove, I'll just paint them in place..
thanks!
Raceguy388
Grant
There is a 10mm bolt holding the tow hook on from the backside. The whole needs to be removed to get to them. I ended up leaving mine on and getting creative with a bunch of tape paper and aluminum foil to paint them.
Johnkn
Maryland
Thank you........
swamp2
Watch the electrical @Johnkn on the driver's side. The connector is a bit hard to open and can cause some significant damage if it breaks from dropping (while connected) in an unsupported bumper. Use a 5 gallon pail or two and some wood. Definitely take it all the way off to paint, i.e. remove bumper, tow hooks, skid plate and plastic cover.
Johnkn
Maryland
Thanks, painting is complete.. I'm not removing the entire bumper assembly to paint the tow tabs when I can mask them and cover the entire hood and front end in 10 minutes..
thanks
