Bottle Jack Lifting Points?
razehound
SoCal
2025 Bronco
Thanks! It seems that my bolts extend a bit further than yours do:
Ford Bronco Bottle Jack Lifting Points? 1784908354606-qk
I'm coming up with some crazy ideas but I think I can make it work... just need to heavily verify before ever actually taking the wheel off
I installed my bolts facing the other direction so the threads weren’t hanging down in the rocks
razehound
SoCal
2025 Bronco
Oh! Now that you mention it that's definitely an interesting design choice.
I may have to do the same. How intensive of a process is that?
Well it was when I was installing new coil overs… so was just part of the install. On stock I can’t recall if those were pressed-in studs or actual bolts that you could just flip.
If they are bolts it would be super simple - just do one at a time and Bob’s your uncle.
If they are pressed in I would just leave them alone and let the rocks take care of grinding them down for you - or you would need to press them out, which would require removing the shock (or at least dropping the LCA off).
SierraBronco
Yeah, stock is pressed in.
There is a reason I didn’t flip mine with aftermarket coilovers though. Can’t remember what it was. Maybe I didn’t like how close the bolt was to the boot with the 32 spline CV’s? Hmm. Not sure
