Bore size
BroncoBeachBuggy
Montauk, NY
F-150
I have read the hub bore on standard Bronco wheels is 93.1, and since it is OEM I assume the center bore is 93.1. Is this correct? Wonder if an aftermarket wheel with a 110 hub bore will fit? Kind of new to this.
GI_Jo_Nathan
Jonathan
It will fit fine. Just won't be hub centric (supported by the hub). Some people don't care, some people think your Bronco will burst into flames. You can buy adapters to make up the difference.
WoolyBugger
MS
Honda Ridgeline / 2dr. Base 7 spd. EG
You can search "hub centric rings" on the internet for your size which would be 93.1 (bronco) to 110 (wheel). You may find plastic or metal but the plastic works just fine. They basically fill the gap between the bore and the hub to create a hub centric fitment reducing a chance of vibration @ the wheel. Hope this helps
