Gotmike
Miami
Stig got photos all the wheel sizes and offset numbers for y'all that are on the rims! Hope this helps with tire upgrade plans! Enjoy.
Table added by @North7
Bolt Pattern:
6 x 5.5 (6 x 139.7)
Center Bore:
93.1
2021 Bronco - Factory Rims : Wheels Specs 2.jpg
2021 Bronco - Factory Rims : Wheels Specs 1.jpg
2021 Bronco - Factory Rims : Wheels Specs 3.jpg
2021 Bronco - Factory Rims : Wheels Specs 4.jpg
2021 Bronco - Factory Rims : Wheels Specs 5.jpg
2021 Bronco - Factory Rims : Wheels Specs 6.jpg
2021 Bronco - Factory Rims : Wheels Specs 7.jpg
2021 Bronco - Factory Rims : Wheels Specs 8.jpg
2021 Bronco - Factory Rims : Wheels Specs 9.jpg
2021 Bronco - Factory Rims : Wheels Specs 10.jpg
2021 Bronco - Factory Rims : Wheels Specs 11.jpg
2021 Bronco - Factory Rims : Wheels Specs 12.jpg
2021 Bronco - Factory Rims : Wheels Specs 13.jpg
2021 Bronco - Factory Rims : Wheels Specs 14.jpg
2021 Bronco - Factory Rims : Wheels Specs 15.jpg
I found this on the options spec sheet that shows each of the wheel options as well you might find helpful
Ford Bronco ⚙ 2021+ Bronco 6th Gen - OEM Factory Rims / Wheels Specs (Sizes, Offsets, Bolt Pattern, Center Bore) ⚙️ 1673980273416
JohnnyMotorBoat
Austin, TX
Ford Bronco Wildtrak 2 Door
Perhaps they had different plans in 2020 or it's a typo, but the Outer Banks and Badlands Standard wheels are mislabeled. Center pic is definintely Badlands and the one to the right is OBX.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
This seems relevant to the thread. Has anyone else noticed that the steel wheels (base for sure, haven't had eyes on a BD wheel) have a significantly larger center bore?
BroncoDude
Sammamish, WA
2014 F-150 3.5EB, 2021 2DR Base 2.7L Auto
I have a Base. Not a larger center bore. There is a black plastic cap that covers it extends to the lug nuts. It makes it appear larger but it is not. Hope that helps.
Tricky Dick
Dick
PNW
I'll measure it tomorrow but it's much larger. If you look at the pictures on the first page you can tell there's much more meat on the aluminum wheels.
hey_mikey_
Mikey
Charlotte, NC
2022 4D Badlands High 7MT, 2019 X7
The aluminum wheels step down from the center bore to a smaller diameter on the outside face because they need to accept a center cap that snaps in. The hole diameter you’re seeing on The outer face of the aluminum wheels is not the center bore size.
Tricky Dick
Dick
PNW
Ahh, you nailed it.
