Blinker fluid question
BlueBronco
DFW
I only use the Motorcraft Original Updated Extra Strength Natural Synthetic Supreme OEM Aftermarket Blended Low Mileage Older Vehicle Prediluted Concentrate Max Mix and not that generic garbage. But you do you.
zuke
Stafford VA
Personnally, I try to stick to the synthetic blinker fluid in modern systems, This appears to be analog fluid, which doesn't work so well with the LED Signature Lighting in a Wildtrak...
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
That stuff’s ok, but you gotta remember to add blinker fluid stabilizer if you aren’t using your blinkers for an extended period of time. Most drivers these days forget this fact and their blinkers cease to work.
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
If I could be a cop for one day, I would write "Failure To Signal Turn" tickets all day long!
BlueBronco
DFW
However, it IS time to deflate all your tires and refill with summer air, (unless like SouthernGirl you live where it is summer all year)
Ha Ha, jokes on you, I paid $499 at my dealership for nitrogen filled tires so I never have to change out the air!
\s
JohnnyBronco
Pennsylania
X4
\s
Back at ya if you intend to air down when off-roading and don't come off the sand or out of the woods right next to your dealer.
Or carry this for $391 a pop - refillable at a welding supply or dive shop near you
Ford Bronco Blinker fluid question 1650292993027
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
\s
You should really switch to Argon in the summer!
this is the best thread in a while.
