Blank/missing switches on dash hero pack
Shacky4
Sault Sainte Marie, Michigan
Big Bend Bronco
I'm going to try and revive this year old thread. My bronco has the 3 switches and a big empty space and no overhead aux switches. I'm wondering if I can swap out the switch bank here with a full set of switches and pick up some aux switches this way. Any new information?
JaxGtc
If it was all software, they would put a full deck of hero switches and some simply would or would not work. The fact that they have to stock and provision different parts makes me wonder why.
PowderP
Iowa
2022 bronco
I’d like to add the 3 switches to my base and add a rear locker.
JimboSlice
South Lake Tahoe, CA
2022 Ford Bronco Outer Banks 2018 Audi Q7
Watching
Sozzy1269
Southern Idaho
23 Bronco 2door, 2012 Raptor, 2017 f350
Keeping this thread alive... Has anyone tried adding hero switches? I'm adding an ARB locker and compressor and would like to wire them to a hero switch. I don't have aux switches either, so this would be an outstanding solution.
Lowcountry Bronco
William
South Carolina Lowcountry
I think this is the part number with the sta-bar disconnect and automatic trans, which should give you all the buttons:
Switch Assembly - Ford (M2DZ-13D730-CA)
It's only $137 from here:
https://www.oemfordpartsdirect.com/...y-m2dz13d730ca?c=bD00Jm49U2VhcmNoIFJlc3VsdHM=
No idea on the connectors, would think if you didn't have options then it would ignore them but how to repurpose them for something else, no clue but it's cheap enough to experiment with.
JimboSlice
I had no idea there was an aftermarket rear locker! Do you have an idea of the install cost for it?
Sozzy1269
Southern Idaho
You have to replace the ring and pinion while adding it. It honestly cheaper to add an entire new axle from a junk yard or Ford.
The labor is around $700 for ring and pinion installed, which includes the Locker install. The ARB locker is about $1,000. I got a deal on mine for less. The ring and pinion was around $280 iirc, and the install kit was about $250. Then you need a compressor and manifold and mount. I went with the single ARB compressor to save a few hundred bucks. Only about $380. Then the manifold was $90. Pump up kit was another $100. Mount was $250. Now I'm looking for aftermarket switch options for hooking up the compressor and some lights... Also went with the ARB rear differential cover for about $180. Not necessary but as long as it's being pulled, might as well upgrade it...
Ducati1098
The switch pack is basically its own module. Not a typical switch pack. The BCM supplies power to the switch pack, but each switch does not have its own dedicated power or ground. The FD-CAN then provides input messages to each of the switched components. So without the input messages from the FD-CAN, the additional switches would be nothing but decoration.
Long story short.. add switches somewhere else.
Sozzy1269
Southern Idaho
Thank you for the straight answer.
