Black Diamond Upgrade to Bilstein Position Sensitive Shocks?
bjellefs
Brandon
Ann Arbor
2011 Ford Mustang, 2008 Ford Explorer
I place an order for a BD and plan to see how it’s rides on and off road the first few months I have it. Then see what Ford performance or the after market scene offers. I mostly will want to ad a level kit at 33’s soon after I get my Bronco, so I’d probably add upgraded shock/struts at that point. These upgrades should be fairly easy if you know your way around a wrench. Will just have to have a professional shop check the alignment when all down.
I agree with this plan. This seems like a good route to go. In all likelihood, the stock suspensions system will be just fine and I won't know the difference.
5280Bronco
Denver
Good question. I believe that the position sensitive feature is controlled by separate reservoirs of fluid and not tied into the electronics system, but I could be wrong on this. Someone smarter than me can probably answer this better.
I don't think it's like magnaride (or the crazy ones on my 05 volvo), etc where the computer is used in conjunction. It should be all within the body of the coilover.
Benji_Allgood
Benji
Auburn, California
Ford Fam
Correct me if I'm wrong, but I believe all Bronco's are standard with the HOSS system. The difference between standard duty suspension and Sasquatch/Badlands suspension is the Bilstein position sensitive dampers. It would be great to see some videos of ride-alongs with the other trims. I'm pretty sure Ford is trying to get people to upgrade to Badlands/Sasquatch with the heavy handed "Badlands is the most capable" hyperbole. I'm thinking I'm going to hold my ground with the unsquatched BD. I think it will be more than capable and fun for my usage.
drive21bronco
North East USA
2021 Bronco Black Diamond
I love the Black Diamond for the fact that its not base base so there is some cool off road tech in it already (probably all that ill ever need) but not totally built up like a Badlands or Sasquatch, giving me a tad of freedom to do some customization to it.
drive21bronco
North East USA
Agreed, The Badlands is really awesome but way to much over kill for me, and probably for most of its buyers but thats ok.
bjellefs
Brandon
Ann Arbor
That is my understanding as well, but my confusion around their usage of the "HOSS" system language is part of my reason for starting this thread. What is the "HOSS" system exactly? The independent suspension? Just the suspension in general? The computer system and goat modes? All of it? I honestly have no idea. The only thing that is spelled out is the Bilstein's being part of Sas, BL, WT, and FE. The rest of what falls under the "HOSS" umbrella is a mystery to me.
Benji_Allgood
Benji
Auburn, California
Ford Fam
Lol nobody knows 🤷🏼‍♂️ I really think Ford wants it that way.
Lowcountry Bronco
William
South Carolina Lowcountry
A little more explanation but HOSS is standard on everything, standard BL and Squatch add to it,
https://www.bronco6g.com/forum/thre...ce-off-road-stability-suspension-system.1847/
Slyder
Washington
2014 KTM 1290R
All Broncos have the HOSS system and the Bilstein shocks are the 'upgrade' to the standard HOSS system on the higher trim levels. I don't think the shocks are controlled by any electronics, though I haven't seen any Broncos up close and personal and going by pictures.
I read in one of the KOH threads where a Ford engineer (I think) said the aftermarket version would be as good if not better than the Factory version.
Now, I don't know if they were referring to the suspension kit Ford will offer or direct from Bilstein, but I'm pretty sure you could upgrade the shocks to Bilstein, Fox or one of the other reputable brands and get similar/equal results for around the $1k range, possibly.
Squatch
wouldn't the position sensitive feature need to be calibrated with the electronics or am I a big dum dum?
It's position sensing in the way that your toilet tank "knows" to stop filling up. Different mechanism, but it's not electronic.
RunningJerk
NW Ohio
2017 VW GTI
Someone somewhere will come out with a pretty good suspension upgrade that will bolt right onto the BD. The "upgraded" billstein shocks look pretty simple to my eyes, with the reservoir just providing more room for fluid. You know FOX will have shocks for the Bronco at some point (if not already) and that any number of aftermarket companies will build shocks for it. My guess is that you'll be able to put a decent set of suspenders on for $2k or less.
bjellefs
Brandon
Ann Arbor
This was extremely helpful and informative, thanks. It does seem like the only difference is the Bilstein shocks. If I am understanding this correctly, the Bilstein shocks are what allow for the difference in suspension travel between the BD and BL trims without any other real changes. Am I missing something or does that seem accurate?
5280Bronco
Denver
Agreed, plus I've always enjoyed modifying my vehicles to make them more uniquely mine. It's part of the fun for me.
Jr87mustang
Josh
Northern Cali
I think your right. I dont think there is much difference at all besides the shocks/strust between sas and non sas. Looks like the Billstien 8100 adjustable shocks run about $800 for a set with the remote reservior. Easy add on. I wouldnt worry about it.
