Bimini Shade Gearshade VS JTop
30snack
2018 F150
Don’t you have to drill something to use the Gearshade with the hardtop?
Jay634
Jay
Toyota 4Runner
For those with the J Top, how quickly can it be taken off or put back on? It looks like the superior product in almost every way, but I really don't want to lost the ability to go fully topless on a whim.
Removal is under 5 minutes. Reinstall is maybe 5 minutes (10 tops - pun intended). You have to remove and reinstall the two brackets that the soft top locks into midway on the cage, but luckily the Ford provided tool kit has what you need and stays in the vehicle. Otherwise it'd take me 30 minutes just to find Torx bit :LOL:.
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
Thanks for dropping by! The only thing that kept me away from the JTop was that it covered the rear speakers and looked like it was a little more difficult to install, but from looking at your thread here it appears that was fixed in the final production units, is that right?
Only other concern with the JTop vs Gearshade is that Gearshade doesn't require you to disconnect anything to close the soft top. Is it correct that with the JTop you need to fold the front back a little bit to close the soft top?
The front flap is magnetic. There is nothing to disconnect. This is a feature we patented 4 years ago and use on all our Jeep JL products. Watch the installation video. Broncosunshades.com.
The reason Gearshade doesn’t require anything is because there is nothing there but a large gap. There is no protection from the wind or sun.
Ford Bronco Bimini Shade Gearshade VS JTop 75975D90-9AC5-4361-A113-B807A1324CD2
Jay634
Jay
Toyota 4Runner
The new version of the Jtop doesn't cover the rear speakers anymore. Not sure about your 2nd question though.
I didn't like the look of the speaker flap either, but the redesign removed that and looks great. I've had it on for a little over a week now and loving it. Flipping the front flap back to fold and latch the soft top isn't that big of a deal. It's definitely not as quick and easy as having not sun shade up there, and requires me to walk to both sides as I'm closing the top so the latch clears the shade, but it's worth it for the nice tight fit and finish.
JTopsUSA
Ram 1500 diesel,
Ford Bronco Bimini Shade Gearshade VS JTop 909B8CA8-115A-43FD-9587-0AA5CE0A394E
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I've got the Bestop Bimini Mesh, and I'm mostly happy with it though I don't care much for the effort of having to reclip the front each time. I like the look of the JTOP better, but there is a good chance I'm going to drop my factory soft top for a bestop at some point, at least as long as MICs are unobtanium.
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I have a Gearshade and I'm very happy with it. I don't feel the flap is too bad driving at highway speeds (75+) and I like that I was able to print my own graphic on it. I feel I'm able to tighten the rear straps pretty good to make it taut. It's pretty easy to take off and the only time I think about the front gap is when people mention it here. The JTops option looks like a pretty solid choice, too. I think you'll be happy with either one. Fwiw, the flap on my Gearshade resembles the JTops video above.
Any chance you could take a pic of the back where the 3 straps wrap around the roll cage? I am curious how tight you have yours. I couldn't get mine tight enough, they would come loose from highway speed occasionally. I do have metal ones from gearshade now that I still need to install, hoping that helps.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I have the Gearshade. I have not been able to get it tight enough to work well at highway speeds.
Anything above 55 and it flaps quite a bit. The back where it clips to rear roll bar makes a flapping noise. Gearshade sent me some new metal clips for the rear straps, have not tried those yet. The original came with plastic rear clips that bowed and wouldn't hold after I tried to furthen tighten it down. If I had not already purchased the Gearshade, I think I would opt for the Jtop based on how it fastens to the roll bar and the sides. The Gearshade is very quick to put on/take off, so there is a tradeoff tho.
I have a Gearshade and have experienced the same thing. Didn’t ask fir metal clips though… Glad to have a JTop ordered. Hope it gets here before a trip at the end of the month.
Jhuff
J
Toyota Tacoma and DR650
I've been using the Gearshade for a couple of months now. Replaced the rear nylon straps with 11" bungie balls. Doesn't stop the flapping (nothing will at 75mph) but I don't have to worry about the straps loosening like they were. The gap at the front is annoying whenever the sun pokes through but that's the only quibble I have.
Waiting on the hardtop variant of the JTop to ship. If it's as well engineered as the Wrangler version (which I once owned), I'll be very happy.
If I keep the gearshade, I will be buying some of those bungees. Thanks! I was really annoyed with the amount of force those hard clips were putting on that thing edge of painted surface.
Not to mention that the gearshade gap provides zero benefit for BestTop softop. The mesh still interferes with the levers and the front/center support Bungie has to be removed to put the top down.
To the OP: I'm seriously liking the redesigned Jtop. If it had been available when I was shopping, it would have been my choice.
Chelada
Bulverde, TX
2022 Bronco
Sure thing. I'll take a picture next time I pull her top down.
Chelada
Bulverde, TX
2022 Bronco
Agreed. That was quite some amount of force it took to screw those suckers in place. As for the clips, I placed a piece of felt under the J-hook to protect the paint.
Hmm, I don't have any interference with the soft top latches. And are you talking about the two bungie/clips above the rear view mirror? I've never had to remove those when opening or closing my soft top.
Jhuff
J
Your avatar shows an OEM Ford Softop? If that's what you still have, I can't speak for that fitment.
But yeah, the middle bungee clips don't fit with my Bestop. And the Bestop latches either make you stretch the gearshade mesh slightly above or below them.
DropHunter
Rudy
Fl Panhandle
1995 Bronco, 2021 Bronco Black Diamond
Man that is a beautiful bronco lol
love the top
when I installed it I actually put the top on with it just being held in place with the magnets. Then I removed one section of Velcro at a time and secured it. The video said give it 24 hours so I closed the top without removing the jtop or pressing the Velcro together. The next night I pulled everything tight and it has been amazing since.
Chelada
Bulverde, TX
2022 Bronco
Gotcha... I hadn't caught that you have the Bestop. Yeah, I can see how that would be a pain.
