Bike Rack Pics
BigFootie
Wisconsin
What's some good electric bike rock options, anyone make a swing out style?
1up-USA.com. The SD rack will hold up to 100lb bikes with tires up to 4” wide. The RakAttach option allows it to pivot either direction.
edit: I’m slightly biased as this is a southwestern Wisconsin company that manufactures their products here. Kuat also makes a pivoting rack adapter.
MoJoe
Saint Louis, Missouri
2023 Bronco Badlands
I have the Kuat rack with the Kuat Pivot, highly recommend!! I love the Pivot because it extends the rack past the 5th wheel and pivots out of the way for access to the tailgate. You can get the Pivot in right or left swing. I went with right swing so bikes can stay off the road when everything is opened up.
Ford Bronco Bike Rack Pics IMG_1025
Ford Bronco Bike Rack Pics IMG_1028
JiuJitsuJoe
Joe
2025 Bronco Badlands⚒
My 1UP USA racks have been good to me.
I own a single rack and a double rack (Super Duty) with the swing out RakAttach🚲🚲.
Ford Bronco Bike Rack Pics IMG_6765
Ford Bronco Bike Rack Pics IMG_7148
Ford Bronco Bike Rack Pics photo-606_singular_display_fullPictur
Ford Bronco Bike Rack Pics IMG_6693
Alassise
Al
One up is the way to go. It is very serviceable and easy to replace parts as they wear out. Had mine for 3 years with no issues. Warranty is superb as one of the bolts came loose and was lost somewhere. Contacted them for a replacement and they sent me a few at no cost. I had to purchase the hitch extension to clear the spare on my Badlands non sas. Worked great.
MickeyT
mzt
Arkansas
24 WT
My set up for two 53# eMTBs -
Receiver: Curt3
Extender: Kuat Pivot, drivers side swing
Rack: 1Up, Heavy Duty, double, black
Tailgate table - @IAG Off-Road drop down table complete my set up area and is super helpful for staging gear (gloves, helmet, etc) or tools (chain oil, wrenches, etc)
Ford Bronco Bike Rack Pics IMG_1157
Ford Bronco Bike Rack Pics IMG_8054
Ford Bronco Bike Rack Pics IMG_9562
Ford Bronco Bike Rack Pics IMG_8055
I also hathe 1Up modular platform tray that I can add to the rack for extra storage (luggage, cooler, etc)
We bike several times a week and this set up has been great
buzzcutt2
FL
I chose the Quikr over 1-up for a couple of reasons. First reason is the fact the it can accommodate up to 5" tire as delivered and the second reason is the ease of adding/removing additional racks without tools. I use the rack with the Kuat pivot for swing away. Having said that, Quikr does cost more.
23OBX2.7
AB Canada
2023 Bronco
Saw a Jeep last week with one mounted to spare tire .....seems sensible.
BigFootie
Wisconsin
Personally, I would not add another 75lbs to the spare tire mount. I know that would be less expensive and easy, but E-Bikes range in weight from 50lbs to 100lbs. The tailgate hinges can be changed to larger more supportive types but even those are done to add larger tires, not support an E-bike or two.
23OBX2.7
AB Canada
2023 Bronco
Good point re ebikes!.
GRB1959
Gordon
Aurora, CO
2021 Ford Edge ST, 2024 Ford Bronco Badlands
I am curious, it appears that most of the bike racks shown in the photos either fully or partially obstruct the rear license plate. Do any of you have issues with getting pulled over by law enforcement due to this issue?
BigFootie
Wisconsin
Not yet, but then I don’t use my front plate either so there’s that. I know 1up-USA sells a plate bracket if you leave your rack on all the time. We generally don’t unless we are traveling with the bikes.
Sloth
SWFL
2022 Bronco
I run the 1Up SD 2 tray rack with the 1Up RakAttach swingout when transporting bikes with my Bronco. Not the cheapest setup, but will be the last bike rack you ever purchase.
