Big Bend 2 door upgrades
Barzo
Canada
Ford Edge
IgnoreUnwatch
Barzo
Ford Bronco Big Bend 2 door upgrades big_bend
I have a 2024 2 door Big Bend on order. I would like to dress up the exterior a bit...nothing extreme. Just for looks. Will not be going off road.
Main thing I see is changing out the stock tires. Any comments on sizing that still works on the stock 17 inch rims? Any comments on tires being "Certified for winter use"?
I have seen suggestions for Toyo Open Country A/T III LT C 285/75 R17Q
I am a couple hours north of Toronto and we are prone to "winter events" and temperatures can get quite frigid.
Any other exterior changes suggested?
  • Like
Reactions: Fly
Falken Wildpeak AT/3 and the new AT/4 are highly recommended winter tires.
Mickey Thompson Baja Boss AT is another that is a highly rated winter-oriented tire.
Not sure about the Toyos you have for winter performance - worth a look - the two tires I listed are definitely not the only good choices
The size you show above I think will work without any modification, it’s a hair bigger than a standard 33”
The rims will accept a wide range of tire sizes - your first limitation will be the crash bars (which just unbolt - easy to remove) or wheels rubbing (which would need a lift or spacers/offset rims to get around)
I think the size you have quoted will fit without any modification but not 100% certain so don’t quote me: more on tire size
https://www.bronco6g.com/forum/threads/largest-tire-size-on-oem-big-bend-rim-without-any-lift.80537/
Barzo
Barzo
Canada
Ford Edge
Thanks, and much appreciated.
Fly
MA
Subaru Outback
IgnoreUnwatch
Barzo
Maybe some running boards? Easier to hop in/out in the winter
Aonarch
Jack Hoff
MT
IgnoreUnwatch
Barzo
That is a great size. Good tire too.
As already mentioned those and the AT3W are very good, with the AT3W being more popular. The new AT4W just came out, we don't have a ton of user feedback yet, but I bet it will be good.
I have those in 255/80/17 on the Ranger and they are a bit squirrely in the wet. I've heard that from others as well.
https://www.caranddriver.com/news/a45861084/winter-tires-new-ice-rating-certification/
There is a new ice rating now too. Not sure what tires have gone through the certification yet. Don't judge a tire if it is not certified, since this is brand new.
Oh also Canadians love Duratracs in the winter.
Barzo
Barzo
Canada
Ford Edge
Those are on the order, so got that covered!
Barzo
Barzo
Canada
Ford Edge
I am hoping the winter certified would be good year round. I currently religiously swap out for winter tires and believe they are a good idea, but if I could save a few nickels by only needing one set year round that would be great. Any other tire experts that can chime in as well? And you Aonarch...
JJ Bronco
Justin
Columbus Ohio
Lexus RX
2 door Broncos all look good. That is going to be a fun ride.
If you like the wheels, I'd say goto a more aggressive looking tire.
When I got to 50k miles I swapped my wheels and tires with some Black Diamond take offs. It improved the look of my 4dr Big Bend.
Do you ski? I always thought a rear mounted carrier like this looks cool on ski days
Ford Bronco Big Bend 2 door upgrades 7656564784837025b29c4763e46977d1
Barzo
Barzo
Canada
Ford Edge
Thanks. Sadly, skiing is one of those things on my list of "usta do's".
