BFG KO3 Coming August 2024?
broox
Derek
Des Moines, IA
broox.com
BMW M4, Bronco Badsquatch
I just got a new set of wheels, logged on to @Discount Tire, and noticed that the KO3s are supposedly coming this August.
Man. I wanna hold out for them, but I really don't think I'll be able to, haha.
Ford Bronco BFG KO3 Coming August 2024? Screenshot 2024-02-17 at 15.42.21
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I’d wait on a review or two, while unlikely it could be a terrible tire
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
Sounds already like a great tire. They are available already. Check out discount tire
lapazleo
2022 bronco badlands
Already available check around a little more expensive than KO 2's
WheresMyBronco
Los Angeles
2023 Badlands
I have them in 35 x 12.50 and even in Load Range E they are fantastic. I wish they were lighter but they perform great and don’t throw rocks.
How's the road noise compared to the Goodyears?
SHANUT
Craig
Hermann, MO
The same or quieter as far as I can tell. I use these tires on all of my heavy duty trucks and they are fantastic. The last set I had on my 1994 F250 lasted 70,000 miles. Like I said, the only knock against mine are that they’re load range E and very heavy. But I put them on as soon as I bought my bronco, so I don’t really know if there’s any performance difference due to the weight. If you can get a load range C or D, I would go for it. Those Goodyears are OK but I’d bet that when Ford knew they were building the bronco they went to several tire manufacturers and gave them specifications and asked for the lowest bid and probably took the lowest bid so I doubt they compare to the BFG’s.
daveness
San Diego CA
2021 4dr Badsquatch, 2018 Sprinter 4x4, 1903 Cad
What is the difference from a K02?
USMCAg
Brazos County, Texas
2016 F-150
I just gave Discount Tire a lot of money for 5 KO2s. Trying the KO3 will have to wait a couple of years.
BroncocnorB
Paul
Clearwater Beach
1965 Cobra,
I still think though that the KO2 tread looks more aggressive
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
The KO3 is a more street oriented tire than the KO2... Also, the OP posted a LR-F tire, that's 3/4 ton truck stuff. No thank you.
If you like BFG's, the KO2 is still a great tire and will be around for quite a while.
GroovyGeek
Boyan
'23 Bronco BD
Thread, sidewall, and weight. Supposedly handle better wet. They have beefier sidewalls and are notably heavier than the KO2. Not sure I want anything heavier than that so when the time comes to replace my KO2s I will likely do another set of KO2s if they are still available.
GroovyGeek
Boyan
'23 Bronco BD
Don't think the KO3 is more street oriented. The wright has increased by at least 7 lbs per tire relative to the 33" KO2 due to increased thickness of the sidewall
