Best speed for MPG performance?
AKBronc49
Russ
Anchorage, Alaska
I just eeked out over 20 mpg in my 4dr, 2.7 Sasquatch on stock Goodyears. I wasn’t trying, but after getting a speeding ticket at the start of the drive home I stayed within 5-8mph. When you combine it with adaptive cruise it makes the trip was less stressful.
Ford Bronco Best speed for MPG performance? 20230514_152843
lakesinai
Charleston SC
I just drove 700 miles from San Diego to Vegas and back. Cruise was set to 77 and I ended at 20.8 mpg. There were plenty of times I kicked it up to 85 to overtake people parked in the fast lane so I’m satisfied with that relative fuel efficiency to time/speed ratio. I found that keeping it in normal mode was more efficient than eco on the hwy. This is in a 2.7 2-door badlands running premium fuel for reference sake.
I find that Premium fuel adds 1-2 mpg to the vehicle.
lakesinai
Charleston SC
I have a base 2DR with V6, 3.73 diff and 10-speed auto. I also installed OBX 32" tires instead of the stock 30s.
I have a high of about 24.5 (calculated) in north California freeway at about 62 MPH (66 calculated with the larger tires). At 64 on the speedo (calculated as 68.27 actual) I can easily get 23 (calculated).
50/50 split between highway and city... I get about 20-21.
Seems like at 70-72 (calculated) I get about 22.5 MPG.
I would think that the OBX 18" wheels & tires would be an excellent upgrade for a Base!
Owl
G
Sacramento
White Wrangler JK, White Bronco Base 2Dr
Yes. I'm quite pleased with OBX wheels and tires.
Got them for a good price, added some Schrader TPMS via America's Tires, and they perform quite nicely. Since 3.73 diff was the standard option for the 18s/32s... I figured they'd work without a hitch. They have done so.
Never tried using Forscan to change the tire size, just realized at 65 on the speedo I'm going about 68.
JZZ
MD
Alot of variables here I’m a 2dr w 2.3 AT and 4.27 rear got 22mpg all day long (real math) and a high of 26 on MD eastern shore which is flat as ya get on stock tires. Have since changed to M/T 255/85/17 34.5” seems to stay 19 to 20 range real math but if your always in the boost mileage will suffer significantly and hills/mountains will force this bottom line easy on the throttle and let the transmission do the work and on the freeway ACC is nice but you will get better gas mileage by learning to lift and for the record I see bo difference between eco or normal
Ford Bronco Best speed for MPG performance? IMG_5252
Ford Bronco Best speed for MPG performance? IMG_5649
Bluestreak57
Al
Gold Bar, WA
2023 Ford Bronco, OBX SaS
Recent trip to Moab from Western Washington… lots of passes, lots of miles at 75-80mph
Ford Bronco Best speed for MPG performance? IMG_1472
Rusty Sheckelford
Rusty
LA
Best mpg you can get going to Florida is pit the Bronco and yourself on the autotrain
But my advice is forget about mpg since to try and travel on I tersystes at less than 81-85 mph invites disaster
I'm really curious how a sasquatch on 33s would look and perform. I want the lift and ability to run 35s but I feel like for the first few years of ownership 33s would be more than enough for me. A nice sweet spot of efficiency and capability for light 4 wheeling and snow driving.
Norm A.
Norman
Driving the freeways of California if I'm doing 65 in the slow lane I still get passed on the right lol
tock13
Tony
WA State
I plan on doing just this if Ford ever builds my order. swapping the Sasquatch wheels and tires for 33s on BB takeoffs. I wanted the lift and more robust front end. I have yet to see pictures of anyone doing this yet tho.
Donkeygyrl
Sheri
San Francisco
Bronco on order
This. I can get 20+ mpg on long distance trips just driving and that includes speeds up to 80 mph. This has been going from Southern CA to Central CA or to Vegas and both have big grades along the way.
I have also been in some 30+ mph sustained head winds with 60 mph gusts, even going 60 mph it was absolutely ridiculous. I was pulling a constant 10+ psi of boost just to sustain that speed in 5th. You can guess how bad my mileage was that day. Went from 22 mpg to...... 13 mpg....
Your pedal habits will dictate biggest factors in mileage that you can change
Yes the brick like aerodynamics are mpg killers
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
I live in FL and my work commute is 30 miles each way, speeds 45-55 MPH with a few stops. I average 22.4 in my 2 door Sas with 2.7. 45-55 MPH will yield the best MPG. I can go up to about 65 and still get close to this MPG. Anything after that it goes down hill. I won't drive it past 70. And I drive very light footed to get this MPG and coast to the lights, no rapid braking.
Techun
Pa
BD, 2.7, MIC, 4dr
Same, except 4dr nonsas. Commute is 45-60 with few stops. 22+ mpg consistently
New2This
D
Dallas
2016 Jeep Grand Cherokee 4x4
I’m getting ready to take a trip to Florida for a week, ~1000 miles, mostly flat. What should I set cruise to to maximize MPG? I’ll be hopefully going to Texas Offrodeo later in year, ~2000 mile round trip, will be using this first trip to set expectations.
Ive got a badlands 2.7 sas. I agree with what most ppl have said.
on a trip from dallas to Austin (~3hrs) I started around 18.5 and by the time I got to austin using lane keeping and adaptive cruise I had 16.5.
The things that sap MPG:
-mud tires (if you inflate to the factory recommended 39-41, you get a little better MPG, less rolling resistance),
-aerodynamics: this car is a flying brick, agree that there is a big change above 60-65mph. you can feel the wind resistance. On long stretches, I pulled up the gauge screen and at 75mph on a long flat highway there is continuous turbo activation 6-9PSI. I'm not a gear head/engineer, but this tells me the engine is working hard to maintain speed
-lower octane fuel. probably very modest effect. I use 93 most of the time. it gets you a few extra horse power. I'm a light foot on the pedal anyway, but I think this lets me be a little lighter.
- how much stuff you are hauling: duh
- Eco vs normal. I don't notice much of a difference in terms of MPG
all that said, I love the car and it did great on the highway.
offroadeo Texas was great. you should also stop at the hidden falls OHV ~30minutes away. fantastic park with tons of long trails, even the "easy" trail was fun with the family.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I get 14.5 no matter what i do. I live in farm country so no stop lights but mileage and range still suck. I know it's a flying brick....
Sardine
2022 Elantra N - 6 speed & 2023 Badlands
1000 ÷ 65 = 15.3846153846
1000 ÷ 75 = 13.3333333333
So two hours difference. Two hours is worth the extra gas money when it's my vacation time.
The one thing you can't buy with even an infinite amount of money is time.
