Best Dash Rail Mount?
CarbonSteel
Colorado Springs
2023 Carbonized Gray
I did some searching, but could not find any consensus. I would like to stick with a no-drill solution.
The Ram Mount seems to be somewhat flimsy given its length and lack of support over the majority of its run.
The BAM Rail is nice, but really long and I think that you have to drill?
I am leaning towards the Tackform Fast Track; does anyone have any feedback on it?
BlueBronco
DFW
I have a rail similar Ram mount. Works great for what I need it for and is plenty rigid. Pic of rail showing my patent pending ball cap clip.
Ford Bronco Best Dash Rail Mount? 1704731183365
CarbonSteel
CarbonSteel
Colorado Springs
Do you have a link to this one?
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
I use the 67 designs full length rail. I had originally ordered the archetype rail, but didn't love how you were limited to the slots and that you couldn't put a ball at the far end. it does install with both adhesive and two screws, and after two year so wheeling with it I kind of wish i could brace it even more.
Bruno
Bruno
Sierras
I wish someone made a rail that goes to the A-Pillars.
Ton of wasted space at the ends and a MUCH better location to mount stuff IMO
Somehting that attached to the grab handle bolts - but then went all the way across
Ford Bronco Best Dash Rail Mount? s-l1600
Ford Bronco Best Dash Rail Mount? s-l960
cr117
PNW
Bronco, EV6
This is the only one I've seen that does that. Probably a bit overkill for most though...
https://vectoroffroad.com/products/bronco-e-dock
Ford Bronco Best Dash Rail Mount? Screenshot 2024-01-08 at 10.42.49 AM
Rydfree
Benny
Alabama
I have the rail from Mabett since it was first released and it has been fine . I painted the end caps and center piece A51 to match the Bronco. It uses standard camera mounts.
https://www.amazon.com/Mabett-Conso...9481&sprefix=bronco+dash+rail,aps,344&sr=8-27
Arokcrwlr
Kraig
US - Alabama
I know you said you'd like no drill/screw, but the Bulletpoint RubiGrid system is awesome. The base does screw to the dash, but in the unlikely event that I ever want to remove it, I'll just get some of those rubber inserts for the dash to cover up the holes.
MadMan4BamaNATL
Ray
Atlanta
I have the full length BAM from AR and can confirm there is no drilling @CarbonSteel.
What you will need is a better adhesive. I just got some better two sided 3M and cut it to the proper size, now the rail doesn’t come up at all nor rattle. You screw in the center part to the existing accessory hole in the center of the dash.
For accessories, I then have 67 Designs arm and MagSafe mount and another for my radio.
Very quality product and should outlast my Bronco. Mine is the Picatinny design. AR will give you a forum code as well.
ElonMuk
Keith
Phoenix, AZ
All the vehicles
67 Designs products are what I use
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
I have the Archtype half picatinny rail, half open rail.
Ford Bronco Best Dash Rail Mount? AR rail
I also just added this grab handle mount.
Ford Bronco Best Dash Rail Mount? 20240108_132322
