BD vs. BL
OspreyFE55
Marc
Navarre, FL
2013 Smart ForTwo
I kind of dig the non-signature lights in front. It's the rears I'm more sad about, and wonder if the lenses can just be changed out.
Forgot about the tail lights! I guess I may have to look at them and figure that out now.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
This is such a tough decision for me. My BD build was $4k less than my BL build. So I need to decide myself if the $4k is worth it for front locker and electric sway disconnect.
Hmmm, where will I go that will require front locker and sway bar disconnect?
Hkak45
K
Illinois
21 Bronco Black Diamond
this is what I’m asking myself. I’m planning a trip next year to take on trails in CO and then head out to Moab. I feel like front locker will be useful out there along with sway disconnect. My current rig I took out sway bar altogether but don’t have a front locker, would have came in handy a few times but not sure if enough times to warrant the $4k yet. Since around Midwest not many places we need it
Benzo
Ben
Bay Area CA
too many to list
The Rubicon is 2.5 hours from me and I will be using my BL there after the shiny parts and newness start to lessen. I don't know too many people that will "need" the sway bar disconnect but it is nice for me to have for my future. If I was not doing the Rubicon, I would get a BD. Note: I have a '70 EB that I use now for the Sierra Mountain rocks.
OspreyFE55
Marc
Navarre, FL
2013 Smart ForTwo
Sway bar disconnect I can deal without, but I know what lockers can do and won’t have another 4x4 without them. I also know how much they are to upgrade later down the road. We also don’t know how hard or if it will be possible to change/add later!
dejones64
Dan
MN
I decided on BD, probably more than what I'll do on the trails, but it's available if I decide to. I can't wait.
Used2jeep
Massachuvian
2007 Crown Vic P71
tyrobronco
CC
Central Florida
2021 Bronco,2017 Ford Fusion Energi
Anyone going with the Standard electronics package?
My BD comes to: $44,730
My preferred BL comes to: $46,060
Difference: $1,330
OspreyFE55
Marc
Navarre, FL
2013 Smart ForTwo
Sway bar disconnect being with a flip of a switch would be nice if you are out climbing some mountains where it’s freezing outside and don’t want to get out to unbolt the sway bar but you are correct. Realistically it’s not “needed” as you can remove the other sway bars manually. Buts it’s a cool feature to have if you are on some trails where you need to get up some rocks, click off sway bar, climb said rocks, click on sway bar and away you go
Yes it’s nice to have the ability to flip a switch, but what won’t be great is when it breaks, or shorts out.
mneblett
2018 F-150, 2019 Mustang GT vert, 2019 Corvette
At which point you break out a couple wrenches, manually unbolt the end links, tie them out of the way, and keep on wheeling. 5 minutes, max. Not a big deal.
In any event, given the pretty darn good reliability of this type of automotive electro-hydraulic system these days, I doubt I'll ever need to crawl under the truck to undo the links.
swampgoat
jeff
b.c. canada
95 bronco xlt 5 speed manual, 2020 f350 tremor
I had the sway bar disconnect break on my 2015 powerwagon. If it wasn't on warranty, it would have been replaced with a regular sway bar from another dodge 2500 (very expensive to replace). Im still trying to decide if its worth getting the BL just for the swaybar disconnect of if I should just go base sasquatch instead.
Xodric
Daniel
Manitoba, Canada ( Born/Raised in Kansas )
1978 Bronco XLT, 1979 F150 4x4
Ford has a trim level problem, or they gave us 3 trim levels and 4 special editions and never clarified that fact.
I would say that for certain, First Edition is a special edition. I mean, it is limited in production and limited to it's standard options, plus it has a custom color option and special graphics. Everyone knows that FE is a special edition.
I would also contend that Wildtrack meets most Special Edition checkboxes. It has custom graphics, it is limited to a unique interior, and it is locked into a group of options. It was the only one going to be available with a glossy black top. It's a special edition all day.
I would also contend that Black Diamond is a Special Edition. It has a unique interior and a unique off-road and unique wheels. it is a low-price-point special edition off-roader.
Base Model is the last special edition. It is more limited in options than the Big Bend, has less colors available, and I doubt ford will put many on dealers lots. (in the future). Base is the fourth Special Edition, like a stripped-down race car chassis.
That makes Big Bend, OBX, and Badlands the three main trim levels. The only confusing part after that is that Sasquatch and the 2.7l has been made available across the board. So that is three Trim levels and four special editions, which would make so much more sense than six trim levels and one Special Edition.
This would line up with Wrangler, where Sport = Big Bend, Sahara = OBX, and Rubicon = Badlands. And the rest are one-off special editions like the Willy's or the 80th Anniversary.
Interesting way of looking at it.
HoosierDaddy
__ Eric
NW. Indiana
Forget about the 35's for a moment, all the rest of the upgraded driveline puts the Badlands far, FAR above every lesser trim until you Squatch them.
Ford's tech reps comment on anything less than a Badlands is 32" tires max.
Keep that in mind.
After adding Squatch to those lesser trims, the price is very close to the Badlands...EXCEPT for a BaseSquatch or BaseManSquatch, which becomes a hell of a value leader for a plain janer with one hell of a drivetrain.
A BaseManSquatch @ $36k-ish (with a winter climate package should one ever exist) would be about all I'd ever need and be happy as hell with it for a long long time.
