BATTERY POSTS
flynndawg
steve
E. TN
2023 Ford Bronco, 2006 Ford F-150, 1989 Ford Mustang GT
im the proud owner of a 23 outer banks and im running a trailer towing harness and was looking at the battery and the added posts for auxillary add-ons and wasnt sure if all 4 are hot since only 2 have nuts on them and i cant tell if the other 2 on the ends are hot... im not finding any good info in the online manual... can someone guide me... thank, steve
thank you... but i guess i can assume they all didnt come with nuts ?
Apparently not. Approximately 50% of Broncos are born without nuts after all.
If i recall the larger one is m6 and the smaller m5
flynndawg
flynndawg
steve
E. TN
:ROFLMAO:🥜 thanks brian
jeffreybehr
Jeffrey
Phoenix, Arizona USA
www.flickr.com
2024 Bronco Raptor 4D
First, I love the color--HotChiliPepper Red?--and bold striping of your Bronco; mine's the same color but has the Raptor splashes.
Secondly, you really need a multimeter if your're doing anything with the electrical system.. Here...
https://www.amazon.com/s?k=multimeter&ref=nb_sb_noss
...are dozens to chose from.
CalvinT
Calvin
Phoenix, AZ
Make sure you buy a good one. I bought one from Harbor Freight and it quick working after a few days. It was probably a bad switch. I returned it and will never buy another. I've never had a meter made for the trades or industry fail like that.
Buy Klein, Fluke, Amprobe, brands that compete on reliability and not price. You want one that won't fail when you're troubleshooting an electrical problem on the trail.
Remember, in this case reliability is more important than the most features for your dollar.
For most folks, I highly recommend the Klein CL390. Runs about $100 - and worth every penny. Can find it at Home Depot and online.
The big reason: It has a clamp-on Ammeter that reads DC current - which is usually pretty expensive to get.
If you want the actual Fluke - look for a 301D. Similar functionality, about $50 more.
flynndawg
flynndawg
steve
E. TN
thank you, i bought her this way, only owned her a couple weeks and my trailer wiring works so im good :)
flynndawg
flynndawg
steve
E. TN
Squatch
Love the two-door and brushed Methods!
You only need a Harbor Freight multimeter. You're measuring 0-20 volts or whether it's hot or not. None of that requires any serious degree of precision.
CalvinT
Calvin
Phoenix, AZ
As long as it doesn't suddently die on you the way mine did. I've worked in electronics from before the time everything went digital. In all that time the Harbor Freight meter is the only meter that's died on me like that. I was helping my nephew with some wiring in his house when it died and I didn't bring a backup. Never needed a backup before.
It's not a problem in your shop and if you have a backup. Not so good if you're in the field and it's the only meter you have.
I like Harbor Freight products, but I'll never buy another of their meters. The low price doesn't compensate for not being able to trust it. .
True, they replaced it. I donated the replacement to a thrift store and bought a Klein.
CalvinT
Calvin
Phoenix, AZ
Almost all meters, no matter who makes them have adequate precision. You're paying for reliability, not precision.
BroncoDave24
East Tennessee
'61 Falcon, '87 F150 XLT Lariat 5.0, '01 F350 7.3L, '24 WildTrak
Use a 5m or 6m bolt on the factory ground bolts. Use them like a stud for your negative / chassis ground points. No modification to the factory connections whatsoever!
