Base Model Bronco Thread
MizzouBronco
Austin, TX
2021 Bronco Reservation
Terribly disappointed with the locked colors behind other packages. Truthfully, living in Texas, it's just downright unpleasant having a dark shade for your Bronco. My two favorite colors were Area 51 and Cactus Grey, both of which are unavailable on the Base.
Definitely curious if they'll have any workarounds on this.
Also, keeping an eye on the Squatch package and whether it is a good deal. The rest is just frills to me.
Fordboi
Cameron
Murica
1966 Ford Ranchero
if you want to squatch you will be required to have an auto
RedRiverRev
Herman
NETSEO
Nothing
Not that I had hopes that the Sasquatch was going to be an affordable package, but the auto only does rub some salt in the wound for those looking for a budget spec.
Fordboi
Cameron
Murica
1966 Ford Ranchero
hopefully that wound heals and they offer a manual with the squatch
Gilveabn
Glen
SF Bay Area
E36 BMW M3, F80 BMW M3, E70 BMW X5
Question on Towing:
It does state that Base model does not have an optional "Towing package". Is there something fundamentally different in the frame/body to other models or does it simply mean that the "tow hitch" itself is an option that you can not choose for Base right of the bat? If that is the case, is Base prewired for a tow and can accept aftermarket or Ford hitch ordered separately? This is how my E70 X5 came - prewired, and I installed Curt hitch without any issues.
Therefore, just in case I have also reserved Black Diamond to cover the worst case scenario.
Fordboi
Cameron
Murica
1966 Ford Ranchero
Question on Towing:
the hitches on there currently is not bolted to the frame. anything bigger would have to be. towing package would prolly do that
Gilveabn
Glen
SF Bay Area
Im not sure I am following you. Do you mean that the Towing Package hitch will be bolted to the frame? And is this configuration that is taking it to 3500lbs tow max capacity? Or do they currently have hitches on that are rated to 3500 and the Towing Package will take it further? I am just unclear on why the Base does not have that option
Fordboi
Cameron
Murica
1966 Ford Ranchero
Im not sure I am following you. Do you mean that the Towing Package hitch will be bolted to the frame? And is this configuration that is taking it to 3500lbs tow max capacity? I am just unclear on why the Base does not have that option
no. no towing package, the hitch will look like this:
Ford Bronco Base Model Bronco Thread 1594846414070
with the towing package it will prolly be bolted to the frame rails, like:
Ford Bronco Base Model Bronco Thread 1594846540214
sorry for the bad drawing, but do you get what i mean?
dgorsett
colorado
F250, Mustang, Explorer
But I believe that crossmember is fully boxed and attached to the frame rails so it should be as strong as a hitch crossbar with ears bolted to the frame rail
Gilveabn
Glen
SF Bay Area
So then what is the Towing Package then if the current hitch is included and rated 3500?
Fordboi
Cameron
Murica
1966 Ford Ranchero
not as big as a hitch with the ears bolted to the frame rail, tho
