Base Model Bronco Thread
dgorsett
colorado
F250, Mustang, Explorer
So then what is the Towing Package then if the current hitch is included and rated 3500?
Usually tow packages include hitch, wiring, maybe improved cooling, certain gear ratios and maybe suspension tweeking. I would bet the 3500 is what any Bronco will tow and once they get it all figured out there will be a tow package including some of these items pushing it to 5000-7500, at least on the 4 door.
Gilveabn
Glen
SF Bay Area
E36 BMW M3, F80 BMW M3, E70 BMW X5
That would be outstanding for me. I need to tow around 4000lbs few times a year - track car on trailer. I do know some Jeep owners that tow 4000lbs 3-4 times a year without issues though.
Jook13
Josh
Prescott az
Suzuki samurai
Seeing as how both the 2 and 4 door are listed at the same 3500 towing rating, it's gotta be a temporary placeholder number. I fully expect the numbers to change, I can't imagine them both being the same.
Fordboi
Cameron
Murica
1966 Ford Ranchero
BAUS67
redneck
Central PA
I believe it's the upgraded version of the "HASS" suspension system. I could be wrong though ??‍♂
I believe the HOSS system is just mainly the reservoir shocks. It's says standard for all models but the Squatch package just has the Bilsteins listed.
TripleB
Georgia
2021 Ford Bronco Base Sas 2.7L, 2026 Ram RHO
Privacy glass issue can be resolved simply by tiningt, correct? I usually go darker than factory tint "privacy" anyway.
Yes I thought of that but I would prefer to not have tint on the defrost glass, assuming it has one.
EcobeastRyan
Ryan
New York
17 fusion se
I currently have a reservation for a base 2dr but after reviewing the trim again I may switch to the big bend because it has the color I want and has auto start. Unless I can somehow get what I want on the base
Pepin10
Pepin10
San diego
Lancer
The four door base also shows No manual trans :(
BE_
1996 jeep cherokee, piece of junk Korean car
after some thinking, i am now 50/50 on whether i should get the black diamond or the base. if i do go base, i would order a 2022:
-2 door
-2.7l
-velocity blue or antimatter blue or OJ white or that dark red (idk i like a lot of colours)
-towing package (if necessary to get a class II hitch)
and i would leave those little 16" pizza cutters on because i think they are funny
i might also get an aftermarket soft top for the weight reduction. you know... i want to see how fast a bronco can really go.
Nickp
Nickp
Nick
Phoenix
Someone on Facebook photoshopped this... THIS is why we need a base manual Sasquatch. That thing would be a BEAST with the crawl ratio manual
Ford Bronco Base Model Bronco Thread 2F15DE82-0186-4B6A-98AC-C2EF9AC955BE
clpray16
Colton
1973 Ford Bronco , Ford Focus ST
Going Base, if the Sasquatch actually doesn't come in manual hoping I can at least spec in the lockers and transfer case everything else will be done by yours truly. But starting to contemplate if I should bite the built and accept an automatic. Color wise I like antimatter blue but want to see velocity blue pictures.
