Base Model Bronco Thread
Inventor
To me, the base squatch is worth it if you plan on off-roading. Gears, axles, lockers, suspension cheaper than the basic BD. A base,2dr mansquatch looks like a whole lot of vehicle for the money. Add the aux switches and then upgrade other things through aftermarket as needed.
I found the Aux switches option on the f-150 listed at only $165.
NCOBX
H2 Hummer, Holden Commodore
Only thing missing is no factory tow hitch/wiring on base.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
Is anyone else mad they are only offering the rear locker with sasquatch? This should be an option for all trims without sasquatch.
I noticed that too. I'd started to settle on getting only a rear locker as an upgrade but found it to be unavailable on the base model.
I also just found out we're limited on colors but after seeking out and getting a bright crazy color for my current car and not loving it so much anymore, I'm okay with getting white or such!
kodiakisland
Arkansas
kodiakisland
Arkansas
I hope that’s at least a junction box for the wiring because I passionately hate cutting into factory wiring.
You haven’t had to cut into wiring in a long time, although some do to save $10. Most of the add on harnesses plug into the blinker/taillight harness.
NCOBX
I don’t think I’ve ever had to buy a harness as every body on frame vehicle I’ve ever bought had a hitch as standard equipment. I wasn’t aware they had harnesses like that.
kodiakisland
Arkansas
Most are plug and play for the specific vehicle and take about 15 minutes to install.
Pancho Kornwallace
Pancho
Mustang
Can you provide a link? I just want to see a YouTube video on how to do it. I recently replaced a taillight on a 2010 Malibu which I thought would be moderately hard because of taking trim pieces off, but with a little YouTube video, I figured out to do it and saved $75 in labor.
kodiakisland
Arkansas
I don’t have a link, but you can search on YouTube as well as I can. Take off the rear taillight lens, unplug harness, plug in new harness, replug original harness, replace taillight lens. If you can work a screwdriver, you can do it.
edit to add:
Here’s one for a Tacoma, which is the last one I’ve actually done.
Lifeliberty
Moonbeam👀
Columbus, OH
Basemansquatch... What is the smallest tire you can put on a Sasquatch rim?
Lifeliberty
Moonbeam👀
Columbus, OH
A
About 235/65R17 (29x9R17) AFIK.
Why??
I would prefer 33s for a daily driver. Want Sasquatch everything except 35s. Wanted to know tire options if keeping same wheels.
It was either keep base wheels and size up or Sasquatch and size down.
