Base Model Bronco Thread
dgorsett
colorado
F250, Mustang, Explorer
ah, thanks! I don’t know why, but I was assuming that was just the 12v (I still need my morning coffee...)
we’ve also seen that 12v on top of the dash, which would make sense given the optional accessory rail.
Maybe it is just 12v, but it looks big enough for USB also. I have also seen the USB on top of the dash in one photo.
EcobeastRyan
Ryan
New York
17 fusion se
Anyone know if you can run a roof rack with the top off?
BAUS67
redneck
Central PA
The 2-door base is looking better each day....get the 2.7 ecoboost and the Sasquatch package and call it a day! Might be under $35k for all this! Sure you won’t have all the awesome GOAT modes available on the badlands and higher trims but you would have a fast awesome bronco! If they would just offer the mid package on the base! It would be the perfect setup but you could live without the mid package....since android auto and Apple CarPlay are standard and you got a 8 inch sync 4 screen and the lcd instrument panel in front of the steering wheel is the same of all models....man Base is looking better to me each day! I ain’t gonna knock anybody going base...because it might be the best way to go....
I was leaning the same way.
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
If the actual colors look like these renders (almost green) I'm in for C-gray. Are there other Ford products I can look at to verify actual color
What I saw on the web looks more light gray/silver than gray - green, its on the Stang E
Ford Bronco Base Model Bronco Thread carbonized-grey-mach-e-mustang-2-jpg
Of course this is CG
Ford Bronco Base Model Bronco Thread Screenshot_2020-07-18 2021 Ford® Mustang Mach-E SUV All-Electric Exhilarating
Ford Bronco Base Model Bronco Thread Screenshot_2020-07-18 Build Price Ford® Mach-E All-Electric SUV
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
I'd like it to be 35k but I am thinking it will be 5-6k for the sasquatch and another 2-3k for the 2.7 and auto...and auxiliary switches, definitely want those. Custom bumper, some BD or Rigid lights to assist the expected anemic ford headlights.
Imissmy1996bronco
2022 JLU Rubicon
The upfitter switches are a standalone option that will be available on every trim level:
And yes, the USB ports are in the media tray in front of the shifter.
Thanks for the clarification! Can’t believe I missed that in the option list.....
BAUS67
redneck
Central PA
@laj.tuxmek is the tailgate/slide out tray/seat thingy standard on all, or option on all, or only in certain packages.
Sorry if you answered it a gazillion times.
BigAl
Al
2006 Honda Pilot
Yes, I believe the roof rack Ford designed for the Bronco stays on when the top comes off. At least the front panel is off in the 2dr pic below. Although it does look like it the back panel might not come off with the roof rack on, looks like it might take some tricky maneuvering for that to happen.
Ford Bronco Base Model Bronco Thread CR-Cars-InlineHero-2021-Ford-Bronco-f-rocks-7-20
Ford Bronco Base Model Bronco Thread 2021-ford-bronco (1)
Scottf
plano,tx
nissan versa
Who is actually putting their money where their mouth is and getting a base model? Count me in! 2-door, base, 7 speed, and sasquatch of course. Going for cactus grey, I am in AZ after all! I will add aux switches if available. Nothing else I really need, I'll go aftermarket!
Im getting the base model, 10 speed auto, sasquach package, with roof rack.
NCOBX
H2 Hummer, Holden Commodore
I'm leaning towards a base 2dr and 7sp manual. I've never owned a 4x4 before. Any idea how capable/incapable the base will be (obviously no hardcore offroad) without Sasquatch package?
Just like anything that’s body on frame, add the right tires and your fine. If you never owned a 4x4 then you definitely don’t need to get the high end with everything and think your invincible.
All of these options - tires, lift, gearing, lockers- they can all be added relatively inexpensively later down the road when you decide you need more.
Base is fine for the majority. Sas package may end up being a good upgrade to many.
thehermdawg10
Clayton
Temecula, California
Toyota Tacoma, 1985 Toyota Corolla GTS
My ideal build right now is the base manual, with AUX switches and thats about it. I can add tires later and for the desert driving I'd be doing, I feel like I can do without lockers and the fancy suspension (correct me if I'm wrong though, I'm a 4x4 newbie)
My only hang up is on color, I have 2 red cars right now and I'd like to get the metallic red, or switch it up to antimatter blue or white. I'm normally not picky with color, but since this is the first and probably only car I'll ever order at launch, I wanna do it right. At least I have plenty of time before ordering to figure it out.
NCOBX
You’ll be fine, as mentioned tires, gears, and lockers can come later as needed. It’s not worth getting hung up on.
NCOBX
How about base and then get the pax coyote v8 installed?
This is the real answer, however I imagine that coyote install will get cheaper as time goes on. You can Duramax swap a suburban for $16k. $30k probably involves a lot of leg work to figure out the basics going forward.
If Ford doesn’t figure out this market then the Coyote is definitely in my future this way.
