Base Lift : KIT VS. USED SaS ?
Bruno
Bruno
Bruno
Sierras
Think I did a Thread “Cactus Steelies”, explaining everything.
right... I actually remember that post! WHere did you get the rattle cans, you dont call it out in the post
FrankenRodz
sheldon
Massachusetts
2022 Base 2 - Door
Automotive Touchup online.
Using them for years.
Takes a month to get it though.
Primer/Basecoat/Clear
Bruno
Bruno
Bruno
Sierras
ok thanks - I have a local shop that makes rattle cans.... Ill check your source to see what they are making + compare cost
mpeugeot
I just picked up a set of 2 door 2.7 sas shocks for our 2 door 2.3 we don't have yet, I think it will be fine but if not you can always get a level kit from Rought country for $59 and put them in the back to come up a bit if you don't like the rake. At least that's my plan at but $200 for the SAS set with stock UCA's and a set of tie rods I couldn't pass it up.
I can't imagine you not being happy with it.
22OBX
Hartford, AL
Honestly most will not notice a difference in spring rate between 2.3 and 2.7 shock/spring. From what I have read about a 100lb difference is all between the two motors.
Just finished my 2.3 OBX Non SAS to 2.7 Badlands Squatch Suspension. About a 4 hour job in the driveway. Nice lift, perfect for my liking and I can tell spring rates are a little higher but still smooth. The Bilstein is a nice upgrade, lot less body roll. I didn’t drop the arm as I wanted to keep alignment close.
Ford Bronco Base Lift : KIT VS. USED SaS ? D10BE829-2361-47D9-9E86-74705AB41344
Ford Bronco Base Lift : KIT VS. USED SaS ? DAA286DE-76F1-4944-8BAA-AD4562741E68
Ford Bronco Base Lift : KIT VS. USED SaS ? 470705D9-9BD8-4D2F-8246-26744B3C13B0
Ford Bronco Base Lift : KIT VS. USED SaS ? 567E4CDF-2EC4-44F0-82EC-03A457ACDEAE
Ford Bronco Base Lift : KIT VS. USED SaS ? C129F956-70E6-4072-9569-9553427413B2
Ford Bronco Base Lift : KIT VS. USED SaS ? 9767F6B3-BA98-408C-BE36-32850464FA73
Ford Bronco Base Lift : KIT VS. USED SaS ? 55076753-19AA-40FE-9213-DA3C63252F86
Ford Bronco Base Lift : KIT VS. USED SaS ? 06D5FB54-50EA-4A1A-B520-BA9B91EBD0FE
22OBX
Hartford, AL
Wheel arch measurements after with 33” tires
Ford Bronco Base Lift : KIT VS. USED SaS ? D173D845-A40D-4A36-9B1C-A5D5F53B5E4E
Ford Bronco Base Lift : KIT VS. USED SaS ? D09695D9-598E-4DD4-BC8A-1A4629EFA060
