BAMF Tailgate reinforcement
Status
Not open for further replies.
Rick Astley
Up Doug's ass
d
We will have that was well, A jerry can will require a door stop most likely so the jerry can doesn't get crushed by the tire and the fender at full swing.
Yes, this is a must-have item!
The 2-door lifestyle comes with a smaller bladder so you need more pit stops. Currently I'm trying to get a system which will allow for a dual Wavian/Nato jerry can holder (with stops to prevent impacts when opening tailgate).
Kholding
Kenny
Las Vegas
2022 Bronco Badlands
Just installed mine. Overall, it's pretty straightforward, but some basic instructions/pictures would have been nice. I struggled with the supplied bump stops as well and am hopeful that BAMF will provide a picture or two of how that is all supposed to go together. I ender up using the original bumps and just threaded the supplied bolt through the tailgate where the crappy factory plastic holder had been (don't over tighten!). Stock wheels definitely don't work well with it (30mm of positive offset). My new wheels should correct the issue.
Overall, it's a quality product and would highly recommend it to anyone looking to strengthen their tailgate.
Ford Bronco BAMF Tailgate reinforcement IMG_7268
Ford Bronco BAMF Tailgate reinforcement IMG_7271
Ford Bronco BAMF Tailgate reinforcement IMG_7272
broncorik
Rob
How many MMs do you predict to clear that lip? I had to add spacers to my wheel to clear my new bumper (15mm), so hoping the wheel will clear my tailgate reinforcement when it arrives. I tried to call BAMF but they never pick up their phone or reply to email, apparently.
Kholding
Kenny
Las Vegas
Hopefully these pictures will help with your question. The bracket is 2" at its widest. I'm guessing the stock 315/70 R17 is contacting it where it is about 1.5"- 1.75" wide at both the top and the bottom.
Ford Bronco BAMF Tailgate reinforcement IMG_7273
Ford Bronco BAMF Tailgate reinforcement IMG_7275
Ford Bronco BAMF Tailgate reinforcement IMG_7278
broncorik
Rob
Thanks! I might be good...I bought Method 705s for the bead grips, and my choice was either +35 or 0 offset...I chose +35 because I am not a fan of tires sticking out past flares. The extra 5 positive would have made it impossible to use that tailgate reinforcement but because I had to clear my aftermarket bumper I had to add a total additional distance over stock of 15mm...so here is hoping it clears ,(that also meant having to add longer studs on the spare tire carrier...no fun). It sucks that bumper manufacturers and tailgate folks are probably using non Sasquatch models to do their CAD designs...or they think everyone wants 0 or negative offsets.
How long after you ordered your bracket did it arrive? And do you plan to get the Jerry can holder if/when BAMF makes it?
Kholding
Kenny
Las Vegas
I think it took about 2 weeks to get it. It would have shipped sooner but they were waiting on the hardware. It's also not powder coated like I thought. I believe it is more like a rhino liner (kind of a rubberized feel). One of the corners of mine was peeling off and looks/feels like a bed-liner material.
I'm not planning on getting the jerry can holder at this point, but that could change.
Ford Bronco BAMF Tailgate reinforcement IMG_7279
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
It’s not powder coated? I’m out.
Kholding
Kenny
Las Vegas
BAMF would have to confirm what coating it has on it. It's not bad, but I thought it was going to be powder coated as that is how they advertise it on their website.
We_Love_Tacos
www.bronco6g.com
If it’s peeling and you just got it, that’s all the info I need to make a decision.
Sewie
Sean
San Jose, CA
74 Bronco, 22 Bronco BL Sas 4D
If it's the same as used on their bumpers.....https://www.bayareametalfab.com/2021-FORD-Bronco-Front-Winch-Bumper_p_169.html?redirect=1
Our powder coating "Included" is unlike anything else in the industry.
It's a completely field repairable thermoplastic coating you can fix with a heat gun or blow torch
(Yeah I said you can fix it with FIRE!). Laid on ultra thick for long lasting protection you will not see anything else like it on the market.
broncorik
Rob
I just wish they would answer their phone or email...sigh...I bought an ASFIR tranny skid plate that works with the Badlands plates and not only did the company respond instantly but they also shipped the plate from Israel in mere days with no waiting period to build.
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
Our powder coating is a a powder coting it's a field repairable thermoplastic not your standard egg shell thermoset.. If it was scuffed in transport a heat gun or blow torch will fix it.
https://www.theprotechgroup.com/brands/polyarmor-2/
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
We took a three day weekend we were not here on Friday. And i have no emails from a rob when did you send an email?
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
So will this not work with Sasquatch wheels and tires? The pics above make it look like it’s jammed against the tailgate reinforcer pretty hard… ❓❓❓
BAMF
BAMF
Jerry
Benicia CA
Two 2021 Broncos
The plus 30mm wheels with the 315 a 1/4" spacer can be placed in between.
Status
