Badlands with 33 or Sasquatch
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
Nope. Badlands is 4.7 gearing. No need for SAS. SAS is suspension, badge, tires.
Nope, Badlands with automatic transmission is 4.46. It's only 4.7 with manual transmission. Squatching an auto Badlands changes gearing from 4.46 to 4.7.
Gamecock
One thing I haven’t seen touched on here is the aftermarket tires available in 33 vs 35 sizes. 35s will get you the looks but if you think you’d prefer a slightly cushier ride then the load ratings in the 33” range are much more favorable.
Cc: @imnewtothis
The stock 35” tires are C rated to begin with...very few people would want to run less than that...C is already marginal at best for an aggressive A/T or M/T and they provide a plenty soft ride. You have to look hard to find anything less than C for a reason...they’re not appropriate for the application.
North7
North Texas
SUV
I would think it depends on the type of driving or ground you plan to cover, would that be correct?
Looking at tiresize.com for the Badlands 33" tires in the 285/70R17 size, I filter on Load Rating SL. Doing this there are 13 tires to select from, in some popular brands and models.
https://tiresize.com/tiresizes/285-70R17.htm
RockEye
Atlanta, GA
2004 Subaru WRX STI, 2DR Badlands Reservation
Tell him that. He never said anything about a manual or auto. You know for a fact it’s made in China? No you don’t. headquartered in Germany with 24 locations worldwide. Funny you say that though. Take your feet out of your mouth Mr. All American responding from a CHINESE made product talking about a vehicle that has many parts made in China. Specifically anything to do with an ECU...have fun driving your Chinese made Bronco as well 🤣
Actually, Ford's ECU's come from Mexico.
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
So Mexican sweat shop vs China makes it better right? 🤣So there’s no parts made in China? And just ccayse it comes from Mehico doesn’t mean no Chinese parts
Gamecock
Dude, you made a blatantly false statement intended to incite, and he corrected you...settle down Beavis.
RockEye
Atlanta, GA
Considering I work for the company that supplies them to Ford, I can tell you the $120 million facility is a high tech and far from a sweat shop. You apparently don't have the slightest clue what goes into manufacturing electronics. Here is a hint, they are not soccer balls or t-shirts.
Ford Bronco Badlands with 33 or Sasquatch ecu
Wizard1183
Lafayette
Get off your high horse. Sorry you can’t read sarcasm 🤷🏻‍♂️
Some of those parts ARE made in China. Reason they produce things in other countries. It’s cheaper.
Atomicdog
Eddie
Philadelphia
sarcasm: "The use of strategies which, on the surface appear to be appropriate to the situation, but are meant to be taken as meaning the opposite in terms of face management. That is, the utterance which appears, on the surface, to maintain or enhance the face of the recipient actually attacks and damages the face of the recipient. ... sarcasm is an insincere form of politeness which is used to offend one's interlocutor."
-Derek Bousfield
Offroadrob
Rob
Summit county Colorado
19 TRD PRO, 10 Cayman S
To sas or not to sas ...
I currently run dedicated winter tires, and plan on doing the same with my bronco. In fact, this is the most important thing for my bronco to kick ass at ... a handful of times every winter I get in some gnarly highway conditions and I try to put as many things in my favor as possible.
Ofc summer rolls around and my needs shift to wants. I want all of Offroad capability I can get.
Currently my order is nonsquatch badlands:
285/70 is no joke off-roading and I think I can do a 265/70 or even 255/75 winter tire with a minimal difference in rpms (2-4%)
but the Sasquatch beckons:
315/70 seems like a lot of fun
255/75 and 265/70 seem out of reach at 7 -9% change in rpm for a given speed, not to mention how strange the stance would be
285/70 seems potentially reasonable at a 5.2%, but that’s still an 11 inch wide tire
anyone have experience or thoughts to add to clarify or further muddle my thinking?
BadSquatch21
PA
Land Rover and Porsches; '22 Mansquatch
Ford made the decision for me by delaying Mansquatch. Ordered manual Badlands, will put on wheels/315's upon delivery. I'm now thinking the smaller flares will look better than the larger Sasq flares. The amount of lift needed will be determined but they've had base Badlands test mules running on 35's so I'm suspecting they'll be ok. Aftermarket will fix soon enough it not.
LagoVistaBronco
Tyler Tx
Mercedes GL350
$2500 is about what five new tires and rims would cost sftermarket
$2500 if you go the cheap route. I’d estimate $600 per wheel for decent quality beadlock rims and tires . Times 5 (spare) add in 4.7 gears and $2500 is a steal.
martyb
Marty
Winneconne, WI
GMC Sierra Denali, VW Atlas
BFG AT KO2 is a fantastic winter tire. I would have zero concern with it for 4-season use. Of course, it isn’t a Blizzak-style true winter tire but those have limitations for most other applications. You could always have some additional siping added to the AT’s
Rivers90
Ben
Southern California
2 Door Base Sasquatch
The 4.46 is what you get with a Non-Sasquatched Badlands that has an automatic transmission.
Sasquatch only comes with an auto right now but when a manual Sasquatch becomes available it will have different gearing 5.13 or 5.38
