Sj2021wildtrak
Seth
Washington
2017 f350 6.7, 2016 gmc Sierra denali 2500
I heard lots of things, including how much they loved the sway bar disconnect and how nice it was that it activated on the roll, off camber and auto reconnected. Many of the comments around “novice” needs were centered around the GOAT modes and one pedal driving, trail control in my recollection. Even then, several commented that the modes worked really well and they would enjoy being able to have those functions work to make the driving experience better, more relaxed and enjoyable when not “competing”. I am fairly experienced, but love the idea of a smoother ride with the sway bar disconnect, trail control for running trails at a regulated pace and one pedal seems awesome both for me and to get my wife into driving off road. None of it is required, but all of it is interesting to me.
I agree it's all nice stuff to have, and the pros did like having those options but to claim wildtrak owners can't rock crawl is 100% incorrect.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Agreed. I think IFS Is more limited in articulation the a SFA equivalent (Jeep), but it will still work well for most any reasonable off road application. I chose the BL for all sorts of reasons, but as much for MGV as sway bar disconnect.
moisea
Moses
Honolulu
Nissan Murano 2015
Photo courtesy of Broncos_south on IG
Left: Badlands. Right: Wildtrak
This photo has me rethinking adding the Sasquatch package.
Maybe it’s the fender flares the Wildtrak looks wider in this pic
Wildtrak looking supreme
BroncoKong Jr.
Andrew
Is there any information out there to suggest that the Badlands with Sas and Wildtrack with Sas have any suspension differences other than the disconnecting roll bar on the Badlands?
I ask because I would think there would be spring and damping differences between one vehicle intended for crawling and another for higher speed stuff.
No difference. Sasquatch is Sasquatch no matter the trim.
Fndinoc
Justin
Phoenix, AZ
The Wildtrack is the Mall Crawler package. Gives the look without the extra functionality (ie Rock Crawl mode, and sway bar disconnect). If you are just doing light 4x4ing its a good way to save some money. But if you watch any of the pro drivers they were all in Badlands or First Editions to get those 2 features.
I don't understand this thought process, do you care to elaborate? As someone who has done some rather aggressive off-roading, I find zero value in the rock crawl mode as I don't need it to auto engage my lockers, I will decide myself which one I want or need, or quite frankly the sway bar disconnect (another thing to break).
At least previously in other vehicles, if I want to go do a off-road trip, I would crawl under and take the sway bar off (or keep it permanently off prior to having a kid).
Am I missing something here? I ordered a Big Bend with a SAS package, so I get the better gear ratio, have all the 4x4 I need, front and rear lockers, 35 inch tires. I chose to get the BB for the cloth seats because I live in Phoenix where leather and vinyl sounds miserable, why would I have any belief a BB would be more capable then a BL for example? The sway bar disconnect?
Streetfish
New Jersey
2014 Toyota FJ Cruiser TTUE
I will be interested to see who jut throws 35s on the standard BL and tells us what happens.
There was that A51 overlanding/camping model that they just threw 35s on standard BL suspension and it looked like it had no room in the wheel well and would probably rub
Erock
US
2018 F150 Alpine edition
Don’t forget axle ratios and all that when deciding between Sasquatch and not... unless you’re only going for a given look.
cbarg14
Clint
Idaho
F•150
My build is on the left. BL, A51, 2.7L, 33" tires w/upgraded wheels and I can't wait! That being said, anyone who thinks the WT rig on the right is a 'mall crawler' is smoking dope. Both are badass rigs.
Jr87mustang
Josh
Northern Cali
Wildtrak actually makes the most logical sense. If any bronco is a “mall crawler” it’s the outerbanks. The wildtrak is the desert runner, the badlands is the rock crawler.
Whats the difference between the OBX and WT? What makes the WT a "desert runner"?
Raptor911
Raptor911
Broadlands, VA
There is no technical reason why the wildtrak can’t have SD but let’s imagine that WT did come with SD and if it did then what would be the difference between the WT and BL?
Does anyone know why the wildtrak doesn't have swaybar disconnect? Is there a technical reason that particular trim can't have it?
BAUS67
redneck
Central PA
Very subtle differences. I still like the idea of a Sasquatch with skinny flares.
Yes !!!!!! ........... Mine too !!!!!!!
Ford Bronco Badlands vs Wildtrak side by side 86C4ADD0-6A3E-4439-97B3-D5D183A6D3C5
Ford Bronco Badlands vs Wildtrak side by side 5A1901BD-14EB-4570-AA82-79B598BC7BE1
Rusty Sheckleford
America
Ford Escape
I do get that, they want that differentiation... but my problem is what if you want a Bronco to do it all? What if you want the the highspeed wildtrak stuff, AND you want a disconnecting swaybar for occasional rock crawling?
I guess what I would like is a "do-it-all" trim above the wildtrak.... perhaps that will be the Warthog? I just hope that it's somewhat affordable.
BroncoKong Jr.
Andrew
The do-it-all trim is the Badlands.
