Badlands grille cost?
murrman
Sean
Toledo, OH
2024 2 Door Black Diamond
I’m looking to replace my current grille (Black Diamond) with either an OEM Badlands grille or an aftermarket one with the same appearance. I’ve found a few used options online in the $250 range, but I’m not familiar enough with the market to know if that’s a good price. I was hoping someone could chime in to let me know what used Badlands grilles typically go for (or if there are any good aftermarket options for a comparable price).
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
I had to replace my grille in November due to a small fender bender. After considerable research I ended up buying one off of Ebay for $250. The Grille is OEM and it looks brand new. It included the letters. There are some on there for $150ish but those look suspect to me. New from Ford is $500+. I think $250 for a new one is a good price.
RoLyMa27
Rodney
SloKart, TX
Here is the seller I bought from.
Ford Bronco Badlands grille cost? 1766499328662-z5
murrman
murrman
Sean
Toledo, OH
Thanks! That’s actually one of the ones I’ve been looking at. How was the quality? It mentions there may be scuffs from handling. Also, do you know if this one is made for models with the front camera? I do not have the front camera, but I’m not sure what the visual differences are.
RoLyMa27
Rodney
SloKart, TX
The quality is great. There were no scratches on mine at all. It looks brand new. I had to use my Dremel to cut two tabs so the camera would fit, so the one I bought did not have a spot for the camera. Visually you can't tell the difference.
This is my old grille. The bars you see between the r & o are there between the o & n in grilles without the camera. If you zoom in on the pic on ebay you can see the bars.
Ford Bronco Badlands grille cost? 1766501621676-
23BDBigSean
Sean
Atlanta, GA
2023 Bronco
Might get lucky on FB marketplace or OfferUp. I’ve swapped grilles about four times now for $200
TFroehner
Tim
Vw gti
FB marketplace worked for me. Included camera mounting parts as well. Didn’t try to talk him lower than $150.
Ford Bronco Badlands grille cost? IMG_9770
Utah Todd
Todd
2023 BroncoBadlands 2 Door
I'm taking my badlands grill off if you are interested and live close?
I'm in Utah.
Ford Bronco Badlands grille cost? IMG20250516114526
