Bad smell on advanced 4x4
drzmat
Canada
2022 Bronco Badlands Sasquatch, 1966 Mustang coupe
Hi guys, i noticed some bad smell on my '22 badlands sasquatch 2.7 when using the advanced 4x4 on regular winter/snow driving.
Never happened on 2wd.
Anyone got this?
Spencersample
Spencer
Canada
Once I used the 4H going off road and smelled the same burning smell that I did when I first got the car, which I assumed was the coatings being burnt off. My dealer warned me of that when I got it.
Once I used the 4H for a while the smell went away? May same case for you?
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
Gears de-greening will often smell due to coatings burning off and them effectively self heat-treating themselves.
Should go away with use. If not then something else is wrong.
drzmat
drzmat
Canada
Yeah i will see how it goes in the next days...
Is there any max speed listed for the advanced 4x4 mode?
I often use it on the highway for snow driving and was wondering....
Lèòn
Jersey
I completely forgot about this.
use 4a in rain for the hell of it, and been off-roading countless times, haven’t smelled anything in ages
Jerad
Washington
2021 First Edition Bronco
I have a 21 FE and am getting like a burning rubber smell, when I come to a full stop it comes in through the hvac.
Smells like a burning belt but everything looks good...not too sure
What the hell is going on.
Anyone got this?
HCGxKaLiBeR
CT
2025 BMW X2 M35i
4A stops sending power (assuming disconnect the front wheels) when you are like 40mph+
You can see the real time power distribution from the configurable gauge cluster.
Jd1539
Dan
PA
Bronco 2Dr Badlands Sasquatch 2.7
Same here. Only 600 miles on my BadSquatch 2.7L.
KABQ
Aaron
Albuquerque, NM
Mine smells EXACTLY like propane after parking in reverse in 4A. It doesn't do it any other time.
John Bronco_ I am here
North America
johnbronco.com
'66 Bronco, '08 JK
The smell is the transfer case getting heated and coatings degassing. The OP must be in some very slippery situations for that to be happening, or the opposite of using locked 4wd on a high traction surface for an extended time.
In normal usage, meaning high traction surfaces, there is very little traction difference between the front and rear axles. With ice, and I mean ice not just wintery weather, you can have a huge difference, the pressure/binding gets the 2 quarts of fluid in the transfer case hot really quickly.
First time I ever noticed it was in my 2003 F550, moved to a cold climate and parked on an icy hill. You can also get the same heat buildup when you are using 4wd on dry pavement for an extended time, there is a binding between the front and rear due to different distances traveled and no slippage between the tires and the driving surface, causes the same tension build-up in the transfer case gears, resulting in heat and therefore the smell.
drzmat
drzmat
Canada
The smell went away after a while, seems ok now.
It was doing it even on wet tarmac, not what i call really slippery stuff....
Can anyone confirm this?
Lèòn
Jersey
Smell came back after offroading with some friends last night
Ford Bronco Bad smell on advanced 4x4 157CF1DD-92CA-4634-9332-DBB11C3EC88D
Ford Bronco Bad smell on advanced 4x4 55F26195-1DFD-4D05-A92D-96A6B2C3D424
Gonna drive without 4A on to see if that helps
MNSnowGoer
Monty
Moorhead MN
2022 Bronco 2 Dr Black Diamond
I just experienced this on some really slushy snowy roads, and some slightly spirited driving in 4a. When I got home and backed into the garage there was a strong burning rubber smell inside, and under the hood, like a an old vacuum cleaner belt.
I sure hope it's actually normal.
On the other hand though, this is the best winter car I've ever had. The downside is you get frustrated with everyone else.
Jerad
Washington
I have been having this same issue for about a month....off and on, stopped doing it and now its doing it again...goes into ford again tomorrow to see if they can figure it out.
Stonetree
Ron
Pittsburgh
2021 Bronco Wildtrak
I've also been having the same issue on and off. Seems to just happen in winter weather. I haven't noticed it when off-roading in the summer. No dash lights or any warnings. Just that smell. Please post here if they find the issue.
